Thread: 98 gtp engine stall restart dies
Results 1 to 4 of 4
  1. #1 98 gtp engine stall restart dies
    Nov 2009
    Missouri
    car dies while driving down road without warning. Try to restart over and over car starts then dies after 5-10 seconds. New fuel pump checked fuel resistor checked for vacuum leaks checked fuses think maybe maf sensor but do not know how to check also have been told ignition control module but do not know how to check that either any suggestions I am losing my mind
  2. #2 Re: 98 gtp engine stall restart dies
    SE Level Member littlerobinson75's Avatar
    wrentham, MA
    i had a similar problem to this in my 98 gtp, i was told basically the same thing as you were. my uncle told me before i start pulling stuff apart or take it to a mechanic, i should check the battery connection, it had some corrosion on it. i removed the corrosion with some fine grit sand paper and i never had the problem again. id say check the connections before anything else
  3. #3 Re: 98 gtp engine stall restart dies
    Donating Users bigmeadersGTP's Avatar
    illinois
    this happened to me for the first time this morning, car starts, stalls 4-5 seconds later like clockwork. Fuse was good, couldnt pull the relay out so I unplugged the maf, same thing. Plugged maf back in, car runs now. Car started and died probably 15-20 times the exact same way before I checked the maf...pretty sure there must be something more...
    Its low, its fast, but most of all....its black.
  4. #4 Re: 98 gtp engine stall restart dies
    Quincy, Mass
    my entire harness was corroded and i had this same problem, replaced the harness during the motor swap and didnt have anymore problems.
    also change the fuel filter.
    No more GP 04 Impala SS Indy:
  1. Driving on express way at 65 mph, engine dies! What the???
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-07-2009, 03:10 PM
  2. stall
    By roadwarrior1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-26-2009, 11:09 PM
  3. Start and Stall
    By l3enner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2009, 06:35 AM
  4. GP Wants To Stall
    By BADAZGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2008, 07:41 AM
