Thread: what oil do you run...
Results 21 to 40 of 42
  1. #21 Re: what oil do you run...
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    5w50 mobil1 when i can get my hands on it, or 5w50 castrol syntec which is always available. - oil pressure never drops and its the the best range you can get for our cars, 5w30 is junk
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  2. #22 Re: what oil do you run...
    Quote Originally Posted by BoostJunki3 View Post
    10w 40 so in the chicago area in the summer would you recommend it?
    do you have an oil pressure gauge? what does it read idling on a 90* day?
  3. #23 Re: what oil do you run...
    Donating Users Warbeaver's Avatar
    St. Louis
    weights can be misleading. for example mobil 1 5w30 is thicker then mobil 1 10w30
    no its not lol 5w30 is like water compared to 10w30
  4. #24 Re: what oil do you run...
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by Warbeaver View Post
    im not gonna waste my time on an argument when there is rock solid proof on their website. look up and interpret the cSt's of both oils and you will then understand
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  5. #25 Re: what oil do you run...
    Donating Users kfish's Avatar
    Ohio
    Quote Originally Posted by kuntzie View Post
    really? 5w-50?
  6. #26 Re: what oil do you run...
    St. Louis
    dunno who your buying oil from cuz they are wrong. Just for ****s and giggles i googled some proof for you. Read the first couple short descriptions on the page.... 5w30 is thinner, hence, why you run it in winter because it flows better.
    5w30 thicker than 10w30 - Google Search
  7. #27 Re: what oil do you run...
    Apr 2009
    stockton ca
    5w30 offerers lower thickness for winter when its colder out thats what the 5w stand for winter weight
  8. #28 Re: what oil do you run...
    Nov 2008
    Fremont Nebraska
    hmmm you must have missed the second half of my post
    "look up and interpret the cSt's of both oils and you will then understand"
  9. #29 Re: what oil do you run...
    SE Level Member NashGT02's Avatar
    Davenport, IA
    planning on changing mine soon and am planning on either mobil1 5w30 royal purple 5w30 or amsoil 5w30
  10. #30 Re: what oil do you run...
    SE Level Member hklvette's Avatar
    Jun 2010
    Christiansburg, VA
    mobil 1 5w30 and a purolator pure one. BTW, oil volume is more important than pressure. Think about it for a second: when lubricating a drill bit for instance, do you want high pressure spray or high volume?
    '05 silver GTP, '98 Cherokee, '78 M880, '70 M35A2
    "Drag racing is for fast cars. Autocross is for fast drivers."
  11. #31 Re: what oil do you run...
    Feb 2010
    yes 5w50.. run i.. you will love it, it basically stays as a 5w weight/ viscosity without thining out at even the harshest driving. therefor staying at a constant 50psi oil pressure even with the car completely heatsoaked 5 w30 5w40 and 5w50 will all be the same thickness at 0*
  12. #32 Re: what oil do you run...
    Charles City, IA
    Quote Originally Posted by hklvette View Post
    How do you think you are going to get the volume to move around the engine? Pressure
    SMGPFC Two Nipple General
  13. #33 Re: what oil do you run...
    SE Level Member Lacboi's Avatar
    Jun 2010
    Atlanta
    well nobody got the zzp oil volume kit? i got it put in but i dont have a op gauge, and i ran 5w30 syn whatever brand is on sale, and i use lucas syn oil stuff to.
  14. #34 Re: what oil do you run...
    SE Level Member Wisconsingrandprix's Avatar
    Aug 2011
    roun here
    i run 15w40 royal purple
    idles about 45-50 on summer day driving about 60-70
    in the winter i run 10w40 with matching presh
  15. #35 Re: what oil do you run...
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Hate newb up the thread but maybe some of you can educate me on this topic. If I live in Seattle and the weather is neither crazy hot or crazy cold what is the best option for me? I am religious about my oil changes and always use Castrol GTX sometimes 20w50, sometimes 10w30 and every so often I treat it with Lucas Oil.
    Am I just wasting money with Lucas Oil?
    Should I stick to the same weight, and does changing it effect performance?
    I drive alot, average about 300-400 miles a week so I do alot of oil changes, if I should change it up let me know thanks.
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  16. #36 Re: what oil do you run...
    Jun 2010
    Indiana
    I would not run 20w50 it is to heavy..the only way I would run 20w50 would be at the track on a very hot day.. or in an engine that is worn out 5w30 or 10w30 is your best bet 5w30 winter 10w30 summer lucus ok..but I would rather put my money on a good synthetic instead !!
  17. #37 Re: what oil do you run...
    Marysville WA
    Quote Originally Posted by JuneBug View Post
    Ok good to know, so should I just switch to Castrol Sythetic or pony up for the RP? I dont mind the added cost I just want to know if its actual making a difference?
  18. #38 Re: what oil do you run...
    Jun 2011
    Detroit, MI
    Quote Originally Posted by h0wl0ngcanitbe View Post
    For the amount of miles you are driving, I would go with Amsoil Synthetic. It lasts up to 25,000 miles and is a very high quality synthetic.
    AMSOIL - Signature Series 100% Synthetic 10W-30 Motor Oil (ATM)
    iLoveSpade
  19. #39 Re: what oil do you run...
    Marysville WA
    [QUOTE=Hippo Machine;656453]For the amount of miles you are driving, I would go with Amsoil Synthetic. It lasts up to 25,000 miles and is a very high quality synthetic.
    Thanks for the suggestion, despite it being rated up to 25k how often would you change this oil? Stay on the 3k schedule?
  20. #40 Re: what oil do you run...
    0W-20 season is upon us... well at least its getting there...
oil, run
