Thread: what oil do you run...
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 what oil do you run...
    Joliet, IL
    ive heard people run 0w30, 5w30, 10w30
    whats your preference and why?
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: what oil do you run...
    10w30, because the cap tells me too. I might do half and half for the winter. 2 5w30 and 3 10w30.
  3. #3 Re: what oil do you run...
    swift current,sask.
    5w30 amsoil, with a wix filter.
  4. #4 Re: what oil do you run...
    GTX Level Member Confusingboat's Avatar
    Minnesota
    5w30 Pennzoil Full Synthetic, because I live in Minnesota and it gets d*mn cold here in the winter. I'll probly go with 10w30 for the summer though.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  5. #5 Re: what oil do you run...
    Quote Originally Posted by Confusingboat View Post
    ,I live in Minnesota and it gets d*mn cold here in the winter..
    Yea it does get pretty cold here, what part of MN you from?
  6. #6 Re: what oil do you run...
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    royal purple 10w30
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  7. #7 Re: what oil do you run...
    Topeka, KS
    Mobil 1 10w30
  8. #8 Re: what oil do you run...
    GT Level Member Lvgrandprix2003's Avatar
    Cincinnati
    Castrol 5W30. I have been running it in my vehicles for over 13 years now. I run what the cap says. and I change my oil every 3K
  9. #9 Re: what oil do you run...
    SE Level Member Milestone's Avatar
    May 2008
    Castrol synthetic 10w30
    Modded.......Yes sir
  10. #10 Re: what oil do you run...
    you guys are missing the point. he is asking about what WEIGHT of oil you run and why. anyone following the oil cap or manual is being mislead. you must right the right weight of oil for your elevation, climate, wear range, etc.
    i ran 10w-40 because even in the hot summer my oil pressures would stay up. when i was running 5w-30 or 10w-30 my oil pressures would drop too low for my liking. i think the thicker oil is what kept my car alive for so long.
  11. #11 Re: what oil do you run...
    Outer Space
    10w30 whatever synthetic brand is on sale. Usually use a purolator oil filter. Run that weight all year long. I run it because I have not had any problems with it. Now in my old truck (bad rings) I run some 20w oil, helps it not smoke as bad.
    02 GTP 13.6 @ 100mph - SOLD
  12. #12 Re: what oil do you run...
    Apr 2009
    stockton ca
    used french fry oil
    10w30 winter and summer
  13. #13 Re: what oil do you run...
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    10w40 royal purple w/ K&N hp-2002 filter, because I get a killer discount at Jegs here.
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  14. #14 Re: what oil do you run...
    Norristown, PA
    Quote Originally Posted by rynoman03 View Post
    Mobil 1 10w30
  15. #15 Re: what oil do you run...
    Charles City, IA
    I ran 5w-30 in the gp all year, 0w-20 in the g6 all year,20w-50 in my truck
    SMGPFC Two Nipple General
  16. #16 Re: what oil do you run...
    GT Level Member SliceTheRice's Avatar
    South Jordan, UT
    I run 10W-30 all year long in my vehicles mostly because the climate. It VERY RARELY gets below 0* here.
    2000 Pontiac Grand Prix GTP
    (3.4 MPS, DHP 1.0 tune, ZZP Plog & 3" DP, 2.5" cat-back exhaust, resonator delete, AL104 plugs, 180* T-stat, Falken Ziex 245/45/18 tires)
  17. #17 Re: what oil do you run...
    Donating Users Warbeaver's Avatar
    St. Louis
    10w-30 synthetic
    I accidentally bought 5w-30 this oil change but put it in anyways. I usually run 10w-30 in summer and 5w-30 in winter. 5w-30 doesnt get so thick when its cold out
  18. #18 Re: what oil do you run...
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Conventional 10w-30 in spring thru fall and 5w-30 for the cold MN winters. My 03 GT sits in a unheated, unattatched garage and it can get to -20* F in MN. Always use a Napa Gold filter.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  19. #19 Re: what oil do you run...
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    weights can be misleading. for example mobil 1 5w30 is thicker then mobil 1 10w30. the cSt is what you should be looking at if your concerned about your oils thick/thinness
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  20. #20 Re: what oil do you run...
    Joliet, IL
    10w 40 so in the chicago area in the summer would you recommend it?
    00 Silvermist GTP
oil, run
