Thread: headers, dp, and low end torque
Results 1 to 12 of 12
  1. #1 headers, dp, and low end torque
    GT Level Member mezzoni's Avatar
    Nov 2009
    Milford, CT
    i see that you guys all say you'll lose more low end torque with headers than you will with a down pipe. so im wondering why that is, besides just the design, i want like a full explanation if possible. thanks
    2006 pontiac G6 GT coupe - the daily
    2001 pontiac trans am WS6 - pacesetter headers, slp exhaust, diablo sport tuner, ported throttle body, ported MAF, SLP intake lid, B&M shifter, UMI panhard bar, lowered on koni's
  2. #2 Re: headers, dp, and low end torque
    Donating Users Ibwrong's Avatar
    Oklahoma City
    This is not a "full" explanation but it has to do with more "flow" the motor flows more therefore you lose some low end torque but not as much as everyone makes it out to be...
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  3. #3 Re: headers, dp, and low end torque
    Willoughby, Ohio
    see i have a GT and i put headers on, the car still moves just fine from a start, actually i like it better now because daily driving is much smoother, and totally worth the pull in the high end...and this is commin from an n/a GP owner ha
    anyway the loss of backpressure means less low end torque, the better flow means more high end torque. essentially your shift your powerband into the higher RPMS so the car wont fall on its face as much after 4500 RPMs
  4. #4 Re: headers, dp, and low end torque
    GTP Level Member Scimmia's Avatar
    QCA, IA
    It's about the velocity of the exhaust gasses. Google exhaust scavenging and I'm sure you can turn up some good explanations. And no matter what people try to tell you, it has NOTHING to do with backpressure.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: headers, dp, and low end torque
    Nov 2009
    Milford, CT
    oh ok ill be sure to google it. and seeing as how bio liked it i know that must be pointing me in the right direction lol
    also, so if i just rev my car up to 4500 rpm's at the line and then launch would that give me a better take of or just spin my tires or do nothing at all?
  6. #6 Re: headers, dp, and low end torque
    Yeah, did you just ask us if neutral bombing is ok?
    God I hope not.
    But if you were serious...be sure to have enough money for a transmission lying around.
  7. #7 Re: headers, dp, and low end torque
    Nov 2009
    Milford, CT
    ok so i wont be doing that lol
  8. #8 Re: headers, dp, and low end torque
    Nov 2009
    Milford, CT
    and no i actually meant holding the break and gas at the same time, but would it do damage either way?
  9. #9 Re: headers, dp, and low end torque
    Charles City, IA
    just stall it to 2k.
    SMGPFC Two Nipple General
  10. #10 Re: headers, dp, and low end torque
    Plus the stock stall only goes so high...probably like 2750 anyways. So you can't go higher than that.
  11. #11 Re: headers, dp, and low end torque
    GTP Level Member
    Nov 2008
    MA
    your not "losing" torque the powerband just moves up
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  12. #12 Re: headers, dp, and low end torque
    Donating Users blowfishRus6's Avatar
    g.a.
    you still have plenty of bottom end with headers. i can leave the line off idle and spin them.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  1. Lug Nut Torque
    By hacket in forum Tires & Wheels
    Last Post: 04-10-2010, 07:04 AM
  2. Replies: 12
    Last Post: 02-08-2009, 01:06 AM
  3. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
  4. Torque anyone?
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 06-18-2008, 10:20 AM
  5. torque..?
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-03-2008, 11:13 PM
