I've searched around and found a rating of 118 for the front lugs on 98-01 GPs. Is it the same for the rear lugs as well?
they're all the same and it's actually 100 ft-lbs.
i've always torqued my wheels at 100 ft-lbs.
i actually had a shop tighten them too much on my 1st 99se and they warped my brakes.
just my 2 cents.
and on cars with crappy lug nut designs you risk damaging them and your studs.
Not to mention repeated over-tightening of them can fatigue the studs...causing a catastrophic failure and loss of a wheel merging onto the interstate. Ask me how I know!![]()
I have never used a torque wrench to tighten my lugnuts. Just hand tighten them all the same. Currently have 75k miles on my pads and rotors and 30k on the wifes.
And I have never broken a wheel stud.Not to mention repeated over-tightening of them can fatigue the studs...causing a catastrophic failure and loss of a wheel
Maybe you guys are doing it wrong.![]()
100 lbs ft.
More torque, or uneven torque, you will damage your brakes, damage your studs, and yes, even damage your wheel bearing due to uneven torque.
You should always torque your lug nuts to factory specks on every car regardless for the above reasons.
This is not a debatable subject, its as good as mechanics law.
~F~
you want a good about of tightness but really its more about it being even so it doesnt pull an warp stuff
That's right! I lost one due to over-tightening. My wheel felt funny so I pulled over to check & one was gone. So I tighten the rest and I snapped another.Crap!
I rode home very carefully and picked up a new set of studs that night.
Put them in & torqued them to 100 inbls. Don't just tighten these bolts. Do it right!
