Thread: HVAC Wiring Issue
Results 1 to 5 of 5
  1. #1 HVAC Wiring Issue
    GT Level Member a3gtp's Avatar
    Feb 2009
    Salter Path, NC
    I recently got my old GTP back from one of my friends, he owned it for about a year before selling it back to me (I needed a reliable car for work etc.). Anyways, within the last 2 months the blower motor stopped working altogether, he never bothered to fix it. So I removed the resistor to find it in horrible shape, next I jumped power to the motor which works fine. So I went ahead and replaced the resistor, the second I turned on the heat the resistor started smoking so I turned it off immediatly. It also blows the HVAC HI fuse the second I switch it to high on the dial. I'm pretty sure I have a short somewhere, I don't think it's the ignition switch in this case since literally everything else works perfectly. The only wire I got power from was the yellow wire on the multi pin connector on the resistor. So, does anyone have a wiring diagram or an helpful information? Thanks in advance.
    BTW I am familiar with the water in the floorboard issue and that has been taken care of.
    If they catch you in the back seat trying to pick her locks they're gonna send you back to mother in a cardboard box.
  2. #2 Re: HVAC Wiring Issue
    Feb 2009
    Salter Path, NC
    Ok, now that I've install a new connector I am getting power to each wire for its speed, the remaining two; thickest of the 2 orange and black have nothing. Black is obviously ground and the thick orange must be something else. My ground must be good since I have good power to all the other terminals so I must have a short in that orange wire. Does anyone have a schematic to tell me where the orange goes?
  3. #3 Re: HVAC Wiring Issue
    Feb 2009
    Salter Path, NC
    Just jumped power to that orange wire, spun blower on the high setting so that must be the wire that bypasses the resistor. Above I mentioned that power was going into the resistor connector (without the res. connected) at different wires with different dial speeds, as it should. With the resistor connected power flows into all the wires at once, except of course the thick orange and black ground. I'm assuming this is because the resistor is now toast. Is there a relay for the blower motor that I am not seeing, there's two mounted behind the glovebox to the right does anyone know what those are for?
  4. #4 Re: HVAC Wiring Issue
    Feb 2009
    Salter Path, NC
    Got it figured out, blower motor was apparently worn out, applied power to it again and the internals started squeling, picked up a new motor and resistor and alls good. The first new one must've smoked since it was working so hard trying to get the blower to spin.
  5. #5 Re: HVAC Wiring Issue
    Jun 2010
    california
    ah stupid motor always do that
    wire mesh
  1. 97 Grand Prix Gt wiring issue
    By GXP Bill in forum Audio, Security & Visual Electronics
    Last Post: 03-14-2010, 09:45 PM
  2. HVAC help
    By 3800SE in forum General Tech Discussion
    Last Post: 03-07-2010, 07:02 PM
  3. 04 hvac
    By Scott Francis in forum Introductions/Noob Questions
    Last Post: 10-16-2009, 03:36 PM
  4. Door Wiring Issue
    By Feather Head in forum Audio, Security & Visual Electronics
    Last Post: 08-21-2009, 09:38 AM
  5. Wiring issue...
    By Iron Indian in forum General Tech Discussion
    Last Post: 08-06-2009, 02:25 AM
