Thread: blower motor relay???
Results 1 to 10 of 10
  1. #1 blower motor relay???
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Does anyone know where these are? I've replaced my blower motor resistor, and tapped on the motor but I still get no fan from any of the speeds. Really don't wanna replace the blower motor. Also what's the best way to make sure I'm getting power to it? Is it supplied from the resistor? Please let me know guys. Thanks
  2. #2 Re: blower motor relay???
    I could guess from your screen name. But I'll make you say it anyhow.
    Year/Model would really help
  3. #3 Re: blower motor relay???
    Oct 2011
    Southington, CT
    Quote Originally Posted by bps02gtp View Post
    i am having the same issue in my gtp. the dealership i bought my car from told me that its the resistor that is causing the issue. i am just waiting on the resister to come in and im gonna replace it and go from there.
  4. #4 Re: blower motor relay???
    you could run a pos and neg to the blower motor and see if it runs.
  5. #5 Re: blower motor relay???
    Nov 2010
    Illinois
    Yeah screen name says it all. 02 gtp. 98,200 miles. Isn't the power for the blower motor being supplied from the resistor tho? So all I would have to do is unplug the plug from resistor to blower and touch the terminals on the inside right?
  6. #6 Re: blower motor relay???
    unless there is a short somewhere. It would at least tell you if your blower is bad or not. Unplug it and run one wire to pos the other to neg and it should run.
  7. #7 Re: blower motor relay???
    Reason I asked is I recently pulled a schematic for an 02 for myself. As I have 3 and 4 only working. Ok. so 1 and 2 are probably the resistor and 5...well good ole 5 shows it going to a seperate power source and I've checked the fuse to be good. So I'll be looking at that schematic again..
  8. #8 Re: blower motor relay???
    Nov 2010
    Illinois
    Wouldn't 3 and 4 be on the resistor too? Do u see relays on there? There's gotta be one somewhere other than where the common places are.
  9. #9 Re: blower motor relay???
    Charles City, IA
    Do you have power to the blower motor? Do you have power to the resistor in all positions?
    SMGPFC Two Nipple General
  10. #10 Re: blower motor relay???
    Nov 2010
    Illinois
    The red and black wire from the resistor going to the blower is what supplies the power right? Jw so I can test and see if I have power
  1. Blower motor is out again.
    By Ravenwald in forum The Rant Forum
    Last Post: 09-10-2011, 09:40 AM
  2. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  3. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
