Thread: Camshafts worth it ?
Results 1 to 20 of 23
  1. #1 Camshafts worth it ?
    GT Level Member AmericanRiceEater's Avatar
    New York
    Hey i was looking at the GT Camshafts and thought about buying some. The thing is i only have headers and a CAI . I was curious if camshafts need supporting mods first ? And would it be more worth it to put off the camshafts until a PCM and pulley,in terms of power wise ? On zzp it said gains 20-30hp depending on your set up. Please help me out here ! Thanks !
  2. #2 Re: Camshafts worth it ?
    Charles City, IA
    putting camshafts in your engine would require a whole engine redesign. It all depends on what you want out of the car for the cam. I would first top swap and do an xp cam at the same time for a nice dd.
    SMGPFC Two Nipple General
  3. #3 Re: Camshafts worth it ?
    New York
    What exactly needs to be re-designed ? And what do you mean by top swap ? Thanks .
  4. #4 Re: Camshafts worth it ?
    Charles City, IA
    Our engine is a push rod engine with a single cam. Putting cams in would require redesigning it to be over head cam, top swap is putting the supercharged top end on the car. Do some searching and you will find every thing you need to know.
  5. #5 Re: Camshafts worth it ?
    New York
    Ok thanks buddy, open to some more input.
  6. #6 Re: Camshafts worth it ?
    Jul 2008
    nj
    What???
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  7. #7 Re: Camshafts worth it ?
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    X2^?????? With am XP I believe you need to mill down the valve guides .100 due to lift. You already have headers and you will need a Tune... The Search button is your best friend here...
    Lambokit to be built!!!!!
  8. #8 Re: Camshafts worth it ?
    for an XP you just need to run modded retainers and the "special" valve seals that the vendors carry that give you 0.020" more clearance.
    Only bigger cams require the guides being milled.
  9. #9 Re: Camshafts worth it ?
    New York
    Can you link me to where i can buy those parts ? And what brand and size cam do you recommend for a car with just headers and cai ? thanks !
  10. #10 Re: Camshafts worth it ?
    first off... how are you going to install the cam?
  11. #11 Re: Camshafts worth it ?
    New York
    I would have my good friend install it for me at his shop.
  12. #12 Re: Camshafts worth it ?
    okay, stock heads or getting them ported?
    Keep in mind its around 800-1000 for a port job at a machine shop.
  13. #13 Re: Camshafts worth it ?
    New York
    stock ssac headers.
  14. #14 Re: Camshafts worth it ?
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Hell for that price you can buy the w-body store heads
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  15. #15 Re: Camshafts worth it ?
    not the headers lol.... the heads
  16. #16 Re: Camshafts worth it ?
    Charles City, IA
    I would not recommend a cam for you at the moment you have no idea what you are getting into or what you want. Figure out what you want out of the car.
  17. #17 Re: Camshafts worth it ?
    Jersey
    read some more, do research, learn the car, then decide.
    16' wrx sti- stock
  18. #18 Re: Camshafts worth it ?
    New York
    That's why i made this post... lol. Thanks for the help..
  19. #19 Re: Camshafts worth it ?
    New York
    Let's put it this way. My car is 100 % stock besides headers and cai . I have enough money in my budget this year to splurge a bit into my GTP and am going to get this job done. I'm obviousley not buying the camshaft until i get some more research done, but that's why i created this post. If you don't have any advice to give other than steering me away from what i truly want to do then don't reply to this post. If your someone that can give me the advice as to what parts i need starting with a nearly stock base and also roughly how much they cost than by all means shoot away. I'm sure there is someone on this forum who started with a near stock base and who have installed needed upgrades to run a camshaft. That's who i would like to give me advice. Sorry to create any confusion and thanks for the help please keep it coming .Thank you .
  20. #20 Re: Camshafts worth it ?
    Crow #105 Springs, Manley Retainers, Heads ported if you want. Install the cam, get the cam install kit from ZZP. Then take them all to your friend and leave them in the front seat for when he does all the work. Then have him tune it...because if he knows how to install all that I hope he knows how to tune your car so it doesn't chuck a rod the first WOT run.
    Have fun skipper.
  1. I know its worth it, but is it really necessary???
    By sdavis11b in forum Brakes/Suspension/Chassis
    Last Post: 05-28-2010, 05:49 AM
  2. How much do you think my car is worth?
    By EJOUIE in forum Off Topic Discussion
    Last Post: 05-06-2010, 12:08 PM
  3. Id say they are worth $100
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 04-19-2010, 08:42 PM
  4. Is it worth it?
    By Chris1999GP in forum Off Topic Discussion
    Last Post: 03-16-2010, 03:58 PM
  5. Is this worth it?
    By undecided in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 03:28 PM
