Thread: i'm confused about o2 simulator i bought from 3800performance
Results 1 to 12 of 12
  1. #1 Re: i'm confused about o2 simulator i bought from 3800performance
    GT Level Member gpbastard's Avatar
    Florida
    Quote Originally Posted by cbeebe1981 View Post
    gpbastard, did everything clear up for you? i am having the same type of problem and I am trying to decide if I want to just buy the simulator or try to get an O2 sensor. I have an aftermarket Catco cat from Summit, so my fear is if I buy an O2 sensor it wont actually fix the problem.
    yes, the simulator did work in keeping the CEL off. but with one stipulation if you have state emisions and that is that the O2 heater shows up on the scanner as a pending code even though the simulator keeps it from tripping the CEL light. hope this helps...
    gpbastard
  2. #2 Re: i'm confused about o2 simulator i bought from 3800performance
    Florida
    Quote Originally Posted by gpbastard View Post
    skip buying a new sensor unless the old one is bad. i have an aftermarket cat as well. put the money into the simulator instead. it seems that a lot of aftermarket cats trip the dreaded p0420 code (on foreign cars as well) even though they would pass an emisions sniff test. i'm in MN and we don't have emmisions testing...
    gpbastard
  1. 3800performance.com's PCM, best choice for my setup?
    By JDCMoney in forum General Tech Discussion
    Last Post: 01-02-2010, 10:04 AM
  2. More info on 3800performance PCM's
    By Durk Diggler in forum PCM Tuning
    Last Post: 08-26-2009, 03:02 PM
  3. O2 Emulator/ Simulator Emissions question
    By Quicklynx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2009, 11:12 PM
