I put a write up in the how to section on doing this, haven't had time to take door apart and take pictures but should help a little. As long as it's a motor issue and not a regulator issue any motor will work, you'll have to disassemble the motor from the regulator sprocket but it's not too hard. Make sure you put a screwdriver between the motor and the sprocket housing so the white sprocket doesn't fall out. If it does then you'll have to spend another 20 minutes trying to rethread the cable. You'll also need a set of star tips to get the door panel off.
