Thread: Vacuum Leak Help
Results 1 to 7 of 7
  1. #1 Vacuum Leak Help
    USA
    I have an '02 grand prix and I think it has a vacuum leak. When I start it the RPMs rise and drop a little bit and sometimes it idles higher than normal. Also i dont know if this is related but after the car is turned off if you try to start it again it cranks a couple of seconds before starting. I tried spraying brake cleaner to find the leak but had no success. What are all the parts/lines that I should be spraying? Could it be something else? there are no codes in the engine. Thanks for any help
  2. #2 Re: Vacuum Leak Help
    Charles City, IA
    sounds like a bad fuel pressure regulator. Check and see if it is leaking gas into the vacuum line.
    SMGPFC Two Nipple General
  3. #3 Re: Vacuum Leak Help
    USA
    Alright thanks. I will check this out when I get a chance. Whats the best way to check it?
  4. #4 Re: Vacuum Leak Help
    USA
    I checked the Vacuum line on the regulator and there wasn't any fuel in there. Is there something else I should check with it? Is it something else?
  5. #5 Re: Vacuum Leak Help
    Charles City, IA
    If you have a vacuum pump you can apply vacuum to the regulator and see if it holds vacuum. If it drops off you need a new reg.
  6. #6 Re: Vacuum Leak Help
    Willoughby, Ohio
    might as well clean your MAF sensor too, just to be safe
  7. #7 Re: Vacuum Leak Help
    USA
    Quote Originally Posted by CTKGP09 View Post
    I just replaced the MAF recently because it was bad
  1. vacuum leak or bad egr
    By mjdennis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2010, 10:49 PM
  2. vacuum leak?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2010, 01:27 PM
  3. vacuum
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-05-2009, 09:09 PM
  4. vacuum leak
    By boredout in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-15-2008, 08:22 AM
  5. Bad vacuum leak
    By boredout in forum General Tech Discussion
    Last Post: 07-14-2008, 02:21 AM
