Thread: Car randomally runs like a** on >1/2 tank
Results 1 to 17 of 17
  1. #1 Re: Car randomally runs like a** on >1/2 tank
    dfw, tx
    Also have a check engine light on now...has 2 codes in the computer
    po300 for a Random Multiple Cylinder Misfire
    and
    po420 for Catalyst System Efficiency Below Threshold (Bank 1)
    and last week while driving around when the car was acting up, it gave me code
    po131 - Oxygen O2 Sensor Circuit Low Voltage (Bank 1, Sensor 1)
    So it seems like whatever it's doing either has to do with the O2 sensors or it's effecting them in some way. And I just replaced the catalytic converter so what are the odds it's already bad?
  2. #2 Re: Car randomally runs like a** on >1/2 tank
    Donating Users kfish's Avatar
    Ohio
    Quote Originally Posted by 99gtxws6 View Post
    and
    going out on a long shot here...but here it is.
    i think your fuel pumps the problem. the 02 sensor low voltage means that your leaning out, which can also cause the random misfire and the catalyst below efficiency code. like i said im going on a long shot, but i do know that low voltage on an 02 sensor like say 200mv is lean and say 900mv is rich. maybe someone else can help you more.
  3. #3 Re: Car randomally runs like a** on >1/2 tank
    dfw, tx
    Quote Originally Posted by kfish View Post
    I guess I'm going to go ahead and put this new fuel pump in. It's starting to have problems now no matter how much gas I've got in it. But it only does it after I've been in traffic a while and it's hot outside still. Kinda weird.
    Like, for about a mile til I get to work, there's construction and traffic backs up, so I'm constantly stopping and accelerating and once I do that for a few minutes, the car starts acting like it's running out of gas. Sometimes it'll die but I can always cycle the pump 3 or 4 times and it'll start again.
    Well Friday it died and I'd turn the key back and forth probably 10 times and the pump would never cycle on. Just let it sit for about 5 mins on the side of the road, tried it again, and the pump cycled back on, car started back up, and I drove the rest of the way to work.
    So hopefully the new fuel pump will do the trick, just hate having to cut and splice the different plug into the stock harness.
  4. #4 Re: Car randomally runs like a** on >1/2 tank
    dfw, tx
    Swapped the fuel pumps and the problem has seemed to have gone away. I've run it under a 1/4 tank many times while in traffic and hitting stop lights and it's not had a problem yet.
  1. Gas tank removal
    By daveg in forum General Tech Discussion
    Last Post: 09-09-2009, 05:17 PM
  2. gas tank?
    By 98gpgt98 in forum Off Topic Discussion
    Last Post: 05-11-2009, 06:19 PM
  3. What size gas tank do I have?
    By tcestes in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-28-2009, 05:44 PM
  4. Metal Gas Tank Flap Broken off and Into Tank
    By indplsin72 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2008, 08:35 PM
