Thread: i need 12" brake upgrade help.
Results 1 to 4 of 4
  1. #1 i need 12" brake upgrade help.
    SE Level Member kirkkarem1212's Avatar
    waterford, MI
    this is a little hard to explain. here goes. i have a 2002 gtp. im doing a 12" brake upgrade. ive bought both front caliper brackets for a 02 monte ss for the new rotors. ok, heres where i need help. the rotor kit i bought comes with all four rotors, for a monte carlo. do i need new caliper brackets for the rear too? or will the stock grand prix ones work with monte rotors?
    3.4 pulley, Borla Cat-Back, Headers, 3" Downpipe, Cat Del, Volt Booster, Trasher Air Box, K&N Filter, Intense Stage 1 Cam, 105# springs, Powder Coated TB, S/C, And Fuel Rails.
  2. #2 Re: i need 12" brake upgrade help.
    Dec 2008
    Lawndale, CA
    Stock rears will work fine.
  3. #3 Re: i need 12" brake upgrade help.
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    yeah, should be the same size.
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  4. #4 Re: i need 12" brake upgrade help.
    waterford, MI
    thanks alot guys
  1. 12" brake upgrade for cheap
    By Silver GTP in forum Brakes/Suspension/Chassis
    Last Post: 08-06-2010, 09:38 PM
  2. 12" front brake upgrade rim compatibility?
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 05-06-2010, 08:22 PM
