Thread: coolant problem and radiator
Results 1 to 13 of 13
  1. #1 Re: coolant problem and radiator
    St. Louis Mo.
    Also moved thread to a more appropriate section
    James Shafer
    St. Louis MO
  2. #2 Re: coolant problem and radiator
    GTX Level Member colindunn's Avatar
    Aurora, IL
    ive heard people say a head gasket cause of bubbles. but when its running for the first 5-10 minutes theres no bubbling. and theres no check engine light on. this is my friends car and a month ago she had the t-stat replaced by an unknown person not in a shop. if they put one in too cold would that be a cause? so if the coolant isnt "boiling" why would it be bubbling? the temp gauge in the car is reading cold. and doesnt raise. i replaced the radiator cap but no luck. you think a bad radiator is causing all of this? or is it fine but not turning on becuse its reading cold. also, if theres air in the system will it cause this?
  1. DNA Headers + Coolant Fans Problem
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2010, 10:08 AM
  2. Supercharger Oil + Coolant Mega-problem
    By element55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2009, 05:43 PM
  3. Bubbles in coolant/ radiator
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2009, 12:27 PM
  4. Shift Interlock Problem & Coolant Gauge Problems
    By 98GTPON22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2009, 04:02 PM
  5. Coolant Elbow Problem
    By Abrasive in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 08:39 AM
