Thread: vac leak i think?
Results 1 to 20 of 20
  1. #1 vac leak i think?
    Joliet, IL
    Ok so at idle my ltfts are at 16.4 which means vac leak.....got some carb spray and sprayed every possible leak area......no change in idle.....wtf i recently put in aluminum lim gaskets with the l32 lim and genv and im running a silicone gasket on sc and tb adapter plate......im stumped.....i guess it could be on the bottom of the tb since i couldnt get alot of spray up there....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: vac leak i think?
    Wichita
    I'm having the same problem. Car idling high, checked everywhere & can't find the leak. Car has a new motor w/ aluminum LIM gaskets. I'm leaning towards both of us having a leak in the LIM gaskets. As the leak hasn't been visually identified...
  3. #3 Re: vac leak i think?
    Largo, Florida, United States
    I had the same issure with spraying and no idle change replace your the Vac line harness from your MAP,SC Snout,Fuel Pressure Regulator, BBV Solenoid
    can buy the complete Vac line harness from GM for like 26$
  4. #4 Re: vac leak i think?
    Outer Space
    What is the serv no on your pcm? If its a 01+ PCM it could be the dreaded cat diagnostic test that makes you run +16.4... but thats only if you have a 01+ PCM and you run a rear o2 sim. Anything done to the rear o2 sensor?
    Also, from my experience ... a really bad MAF tune can do that. I saw that after I cammed my car.
    02 GTP 13.6 @ 100mph - SOLD
  5. #5 Re: vac leak i think?
    Joliet, IL
    Quote Originally Posted by Lawngoose View Post
    well i have a half ass maf job on my car until i get it retuned, i just have a basic lq4 bin on it and my inj. flow rate increased for the 65#'s, could i get this from running pig rich, my exhaust smells rich....?.....its only +16.4 once the car heats up.....if my LIM gaskets are leaking can i remove and reseal without ruining them? i got a 00 pcm with no rear o2 and codes deleted.
    00 Silvermist GTP
  6. #6 Re: vac leak i think?
    if you have the stock cam you should still have around 20 " of vacuum.
  7. #7 Re: vac leak i think?
    Outer Space
    You got a boost gauge right?
    I bet that's not helping, since your MAF values correlate with your LTFT's. When you get your MAF straight... start a MAF tune, with the correct values for a LQ4.
  8. #8 Re: vac leak i think?
    Im confused as to why my post is quoted. Forgot to mention something else there?
  9. #9 Re: vac leak i think?
    Joliet, IL
    stock cam, 1.95 rr and yes i got a boost gauge it sits right at -20 at idle......i have the correct values for an lq4 but none of them have been altered i just put it on the lq4 so it would start up and idle i have done any "tuning". i having a friend do the nitty gritty tuning.
    i didnt rtv the gasket guides across the valley area tho....i only did the gasket pieces! do i need to rip it apart and re seal that area?
    00 Silvermist GTP
  10. #10 Re: vac leak i think?
    Outer Space
    Ok, according to your boost gauge it doesnt sound like a vac leak. Just a wack MAF or tune.
  11. #11 Re: vac leak i think?
    this.
  12. #12 Re: vac leak i think?
    Joliet, IL
    this.
    ok good.....what would my boost gauge be showing during vac leak how far off would it be?
    00 Silvermist GTP
  13. #13 Re: vac leak i think?
    Joliet, IL
    my maf tune is not even a tune lol we just re entered the hz numbers for a lq4
    00 Silvermist GTP
  14. #14 Re: vac leak i think?
    Outer Space
    Quote Originally Posted by BoostJunki3 View Post
    You would have less vacuum ...
  15. #15 Re: vac leak i think?
    Joliet, IL
    lol why thanks.....would it be alot or very minimal? like 18 or 10 is what im getting at.
    00 Silvermist GTP
  16. #16 Re: vac leak i think?
    Outer Space
    I would depend on the size of your leak... I would think. I think its your MAF Table. Get some one to help you MAF Tune it.
  17. #17 Re: vac leak i think?
    Joliet, IL
    Weird how it sits at like 5 and 6 when i first start....the minute the motor is hott it shoots right up to 16.4
    00 Silvermist GTP
  18. #18 Re: vac leak i think?
    youre seeing the transition from open loop to closed loop.
  19. #19 Re: vac leak i think?
    Joliet, IL
    ok so your def thinking i have no vac leak then? thank god i just put the shyt back together and didnt wanna tear it apart.....i had to torque the SC bolts to 14 ft/lb instead of 17 ft/lb due to the silicone gasket....would u guys reccommend oem gaskets over silicone ones?
    00 Silvermist GTP
  20. #20 Re: vac leak i think?
    i always liked OEM gaskets, but if its sealed then i dont see a reason to switch.
  1. Oil leak!!!!!
    By musiknjoyr in forum General Tech Discussion
    Last Post: 02-02-2010, 12:15 AM
  2. oil leak
    By littlenoz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-15-2009, 07:19 PM
  3. Vac leak?
    By Sandman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2009, 07:24 AM
  4. Bad oil leak
    By evilpacker in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-29-2009, 09:56 AM
  5. Oil Leak
    By streetsmart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2009, 12:45 PM
