Thread: fuel line nut rusted to fuel line!!
Results 1 to 20 of 33
  1. #1 fuel line nut rusted to fuel line!!
    Brewcity, WI
    I went to change my fuel filter and found this...
    http://i162.photobucket.com/albums/t...0/IMG_0165.jpg
    I have tried 1/4 can of PB Blaster, another 1/4 of penetrating fluid, 2 sets of vice grips...Which in the pic. you can see is Deff. grabbing the nut. But I can't for the life of me break the filter loose from the fuel line!!! I've sprayed, tapped, sprayed, tapped... nothing
    very close to using a torch...jk
    Self-denied SMGPFC member #1
    SEARCH works!
  2. #2 Re: fuel line nut rusted to fuel line!!
    Apr 2009
    stockton ca
    ya a torch would work make sure to vidio it ive never used a torch and want to see how its done
  3. #3 Re: fuel line nut rusted to fuel line!!
    Brewcity, WI
    seriously.........
    SEARCH works!
  4. #4 Re: fuel line nut rusted to fuel line!!
    Charles City, IA
    Quote Originally Posted by TorqueAutoMotiv View Post
    I watched a guy almost due that. Not sure if he did heat it up with the torch or not I left the room.
    SMGPFC Two Nipple General
  5. #5 Re: fuel line nut rusted to fuel line!!
    Apr 2009
    stockton ca
    seriously you may just be **** out luck
  6. #6 Re: fuel line nut rusted to fuel line!!
    Brewcity, WI
    I was thinking about using some sort of flexible rubber tubing, but I'm not sure thats possible.
    Thinking about just cutting the line and using a brass adapter with a piece of hose. I think I'm pretty much ****ed anyways.....
    ****ingWInter
    I'm hoping thats its gotta do something with the leaverage
    SEARCH works!
  7. #7 Re: fuel line nut rusted to fuel line!!
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    you could do something like this maybe
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  8. #8 Re: fuel line nut rusted to fuel line!!
    if you cant get the nut to move youre going to have to cut the lines and replace, dude. not trying to make your job a lot harder, but i was lucky enough to get mine off. i only replaced it once on my car and never again.
  9. #9 Re: fuel line nut rusted to fuel line!!
    GTP Level Member KwazrollinZ28GTP's Avatar
    FLINT/michigan
    i got mine off and it was no problem at all, but i'm having this damn problem on my buddys, 5/8 wrench and a 3/4 wrench and then i tried big ass vice grips and still nothing, i even sprayed it every day with pb blaster for 2 weeks and still nothing ~~~!!!! i may just cut it like you said. but I'm iffy with sparks and gas, so i told him to take it in haha
  10. #10 Re: fuel line nut rusted to fuel line!!
    Brewcity, WI
    Quote Originally Posted by KwazrollinZ28GTP View Post
    I've used a 13/16" on the filter?....granted close enough. I tried for 2 days/2-3 hours total, and said **** it. Will let someone else deal with it. Though they will probably kink the fuel line and charge me for it.... which kinking it was my biggest fear. Looks like my fuel/vapor/brake lines are all getting rusty anyways...
    SEARCH works!
  11. #11 Re: fuel line nut rusted to fuel line!!
  12. #12 Re: fuel line nut rusted to fuel line!!
    Largo, Florida, United States
    use a fuel line cutter....
    mine is rusted on as well. whats this "Fuel Line cutter" look like? i have a new fuel filter just waiting to go on.
  13. #13 Re: fuel line nut rusted to fuel line!!
    Charles City, IA
  14. #14 Re: fuel line nut rusted to fuel line!!
    Brewcity, WI
    could u/i use some sort of rubber tubbing with a brass nipple into the filter? Only flexible fuel line is see is for chainsaws, traxx cars, weedeaters, etc. Not looking to mess with braided lines...
    SEARCH works!
  15. #15 Re: fuel line nut rusted to fuel line!!
    Similar (or the same) as just a tubing cutter.
  16. #16 Re: fuel line nut rusted to fuel line!!
    Naples
    Sounds like my car, a gift from my father, from wisconsin the whole inderbelly is rusted from the road salt, im hoping that its all surface rust...pray to the upper ones lol
  17. #17 Re: fuel line nut rusted to fuel line!!
    bg ky
    Take the fuel filter retainer off and turn the filter instead of the line it the line will not turn but the filter will not be a loss if you tare it up i have done several this way with no problems.
  18. #18 Re: fuel line nut rusted to fuel line!!
    GT Level Member gpbastard's Avatar
    Florida
    Quote Originally Posted by max98 View Post
    i did the fuel filter on my car recently and yes the fuel line nut is stationary. hold it with a pair of lockjaws if necessary and turn the filter with a wrench. if you do get it off make sure to use a little anti-sieze on the filter threads but keep the top 2 threads free of anti-seize and next time you won't have this problem. again. the fuel line nut doesn't turn...
  19. #19 Re: fuel line nut rusted to fuel line!!
    Donating Users Rust's Avatar
    Jun 2010
    Canada
    There is a product made by Rust Check called FREEZE.
    I assume its like liquid nitrogen in a can. Spray it with liquid wrench, hit it a couple of times with the FREEZE and keep tapping it with a wrench.
    Its called cold shock. Some of the rust started flaking off in chunks.
    Didn't mess up my fuel at all and it worked!
    Shocked the hell out of me.
    Spent weeks trying then turned like nothing was ever wrong.
  20. #20 Re: fuel line nut rusted to fuel line!!
    gaiz... just turn the ****ing filter instead of the nut... its VERY simple.
  1. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  2. Fuel line disconnet
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2009, 08:22 AM
  3. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  4. fuel line identification help
    By sra_chipmunk in forum Off Topic Discussion
    Last Post: 07-06-2008, 12:30 PM
  5. AN Fuel Line Setup
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2008, 06:26 AM
