Thread: fuel line nut rusted to fuel line!!
Results 1 to 20 of 33
  1. #1 Re: fuel line nut rusted to fuel line!!
    bg ky
    Take the fuel filter retainer off and turn the filter instead of the line it the line will not turn but the filter will not be a loss if you tare it up i have done several this way with no problems.
  2. #2 Re: fuel line nut rusted to fuel line!!
    GT Level Member gpbastard's Avatar
    Florida
    Quote Originally Posted by max98 View Post
    i did the fuel filter on my car recently and yes the fuel line nut is stationary. hold it with a pair of lockjaws if necessary and turn the filter with a wrench. if you do get it off make sure to use a little anti-sieze on the filter threads but keep the top 2 threads free of anti-seize and next time you won't have this problem. again. the fuel line nut doesn't turn...
  3. #3 Re: fuel line nut rusted to fuel line!!
    Donating Users Rust's Avatar
    Jun 2010
    Canada
    There is a product made by Rust Check called FREEZE.
    I assume its like liquid nitrogen in a can. Spray it with liquid wrench, hit it a couple of times with the FREEZE and keep tapping it with a wrench.
    Its called cold shock. Some of the rust started flaking off in chunks.
    Didn't mess up my fuel at all and it worked!
    Shocked the hell out of me.
    Spent weeks trying then turned like nothing was ever wrong.
  1. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  2. Fuel line disconnet
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2009, 08:22 AM
  3. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  4. fuel line identification help
    By sra_chipmunk in forum Off Topic Discussion
    Last Post: 07-06-2008, 12:30 PM
  5. AN Fuel Line Setup
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2008, 06:26 AM
