i was thinkin either bad fuse, or turn signal flasher relay, because it works fine when im idling or apply pressure to the gas peddle...only when i hit the brakes does it not work in the front OR the back...
check the fuses and relays like you said also the grounds on the car? electrical gremlins suck!!
buddy was saying something similar, but he needs to hit his brakes to make his blinker work on the left side... lumina
how could it be the fuses if the right one works perfectly, and the left one doest work ONLY when i apply the breaks
??? going to autozone today to check out turn signal relays and wiper blades, then going to get my ac recharged wish me luck
