Thread: Can you tell what I want?
Results 1 to 20 of 24
  1. #1 Can you tell what I want?
    Norristown, PA
    Can you guess it?
    On a more serious note, I'm going to tune up the car tomorrow. I'm going to do oil change, oil filter, tranny fluid, filter, plugs and wires. Anything else I should do?
  2. #2 Re: Can you tell what I want?
    Apr 2009
    stockton ca
    new 02 sensor if its the stock one(orig one) run some seafoam ]
    fuel filter
  3. #3 Re: Can you tell what I want?
    You need gas soon????
    check power steering fluid, and winshield washer fuild and check tire pressure
  4. #4 Re: Can you tell what I want?
    Norristown, PA
    I have about a half tank of gas. Nobody can figure out the picture?
  5. #5 Re: Can you tell what I want?
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    um, adding the cool stock boost gauge?
    check ur belts and pcv too
  6. #6 Re: Can you tell what I want?
    Brewcity, WI
    Quote Originally Posted by TorqueAutoMotiv View Post
    fuel filter
    What he said.... Also clean the MAF (don't touch it) with some QD electrical contact cleaner, which can be found at Home Depot
    I was hoping that was 1/2 a tank, but seems like more........but I'm in the process of a tune-up/fix
    Self-denied SMGPFC member #1
    SEARCH works!
  7. #7 Re: Can you tell what I want?
    Norristown, PA
    Already cleaned the MAF then returned the can. Still nobody can see what i want in the picture?
  8. #8 Re: Can you tell what I want?
    Brewcity, WI
    Dugh... same thing I want......BOOST?
    SEARCH works!
  9. #9 Re: Can you tell what I want?
    a bottle of something that is 16.7 oz.?
    $167 worth of candy???
  10. #10 Re: Can you tell what I want?
    Norristown, PA
    Your close, but it has nothing to do with a boost gauge.
  11. #11 Re: Can you tell what I want?
    Brewcity, WI
    um so you wanna go on a 167 mile vacation?
    SEARCH works!
  12. #12 Re: Can you tell what I want?
    Norristown, PA
    No vacation, although I am excited for senior week in 3 weeks.
  13. #13 Re: Can you tell what I want?
    swift current,sask.
    Performance shift?
  14. #14 Re: Can you tell what I want?
    Norristown, PA
    Thats not it, that would be nice though!
  15. #15 Re: Can you tell what I want?
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    L67, people. so either a GTP or a top swap.. or motor swap
  16. #16 Re: Can you tell what I want?
    Brewcity, WI
    agh... nice. Was thinking about l not L
    Performance shift?
    can't you just ground pin 21 (blue) on the PCM.... totally going of the top of my head. Did it like 3 years ago...... * researching*
    http://www.rivman.com/perfshift.htm
    SEARCH works!
  17. #17 Re: Can you tell what I want?
    West Side Michigan
    Hmm..... something is missing above the picture of the car
    You should go get that checked out lol
  18. #18 Re: Can you tell what I want?
    Donating Users kfish's Avatar
    Ohio
    i get it...i think
  19. #19 Re: Can you tell what I want?
    Brewcity, WI
    Figured it out..... the doors not open and he can't get out!
    sorry...drinking
    SEARCH works!
  20. #20 Re: Can you tell what I want?
    Minnesota
    Different color LEDs? that or supercharger
