Thread: Rich vs Lean
Results 1 to 12 of 12
  1. #1 Re: Rich vs Lean
    GT Level Member 02blackgpgt's Avatar
    Jan 2009
    Kennesaw, GA
    Quote Originally Posted by cerick08GP View Post
    Well let me put it this way, running lean might burn a hole in a piston or two. And running rich will probably only result in bad mpg. It is a tough choice you’ll have to deal with.
    lol its a tough choice
    Quote Originally Posted by blowfishRus6 View Post
    run it rich, its safer for now. change the oil when you get back and get a maf.
    I changed the oil yesterday. Would I still need to? Why would I need to?
    if it wasnt an automatic front wheel drive four door grandmas car it would be really nice
    Mods?? What the f#ck is a mod??
  2. #2 Re: Rich vs Lean
    Donating Users blowfishRus6's Avatar
    g.a.
    Quote Originally Posted by 02blackgpgt View Post
    all the unburnt fuel can wash down the cylinder walls and get in your oil.
    over time it will start to cause issues. bearing failure, can wash the oil off the cylinder walls and cause the rings to scuff the walls and possible break rings. lost of compression and potentially chip pistons when/if the rings snap off.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  1. Rich Condition HELP!
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2009, 04:51 PM
  2. running lean or rich + white smoke on idle
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 08:51 PM
  3. car running really rich
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 04:48 PM
  4. Rich Neighborhood :D
    By blueguy in forum Visual/Body Modifications
    Last Post: 05-15-2009, 12:06 AM
  5. Car runs rich and surges at an idle?
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2008, 02:54 PM
