Thread: Thermostat problems?
Results 1 to 10 of 10
  1. #1 Thermostat problems?
    SE Level Member Amb4's Avatar
    Nov 2009
    Canada
    I installed a 180 t- stat a while back and havent really had any hot days to see if everything was working out fine. Anyways today i was driving and my coolant temps were above 200 while stopped and hovering around 195 while driving? why would this be happening. Should i just replace the t stat? Thanks
  2. #2 Re: Thermostat problems?
    Charles City, IA
    Bleed the system.
    SMGPFC Two Nipple General
  3. #3 Re: Thermostat problems?
    Apr 2009
    stockton ca
    do you have a tuned pcm? may be a stupid qustion but you never know
    and yea you probably have air in the system
  4. #4 Re: Thermostat problems?
    Nov 2009
    Canada
    nope no tuned pcm at the moment, is that why my t stat wouldn't be working? lol i didnt know that. But i also probably could have air in the system because even if the pcm is programmed for 195 it was above that today so it should have kicked in
  5. #5 Re: Thermostat problems?
    your fans dont turn on at a low enough temperature to make a difference. you need to tune for it.
  6. #6 Re: Thermostat problems?
    Nov 2009
    Canada
    alright, well im still waiting for my tune to come in. So hopefully all is fixed with the proper tuning.
  7. #7 Re: Thermostat problems?
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Mine did the same thing. Tuned for it sunday all good now temps never go above 185 now
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  8. #8 Re: Thermostat problems?
    GTX Level Member cerick08GP's Avatar
    Quote Originally Posted by Amb4 View Post
    You should be fine when the tuned PCM is installed, most of them come standard with the fan settings to support a 180F t-stat unless you request different.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  9. #9 Re: Thermostat problems?
    Jun 2010
    New holland, pa
    so will getting a 180 t-stat make any difference without a tune?
  10. #10 Re: Thermostat problems?
  1. Thermostat...
    By TorqueAutoMotiv in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-13-2009, 11:20 PM
  2. Thermostat!????
    By fratzke7 in forum General Tech Discussion
    Last Post: 03-16-2009, 11:35 AM
  3. thermostat
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2008, 06:38 PM
  4. 180 thermostat
    By LMCOOK87 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2008, 03:00 AM
  5. What Thermostat Should I Get ?
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-10-2008, 07:00 AM
