Thread: The air in my car still wont change
Results 1 to 4 of 4
  1. #1 The air in my car still wont change
    SE Level Member xsvtank's Avatar
    NJ
    i have a 98 gtp i still cant get my air to work (ac/heat) i hear it blowing and all the vac lines are connected. when i change the vents to either defrost or feet or body they dont change it stays exactly the same what should i do?
    there is a grand prix being parted out close to me wat would i need from it to fix my air
    Thankyou
    Frank
  2. #2 Re: The air in my car still wont change
    Charles City, IA
    The arm could have cam unhooked that moves the doors, not sure where it is on a gp tho, I think it is under the dash behind the center consul.
    SMGPFC Two Nipple General
  3. #3 Re: The air in my car still wont change
    NJ
    does anyone know where it is?
  4. #4 Re: The air in my car still wont change
    somewhere
    I had this exact same problem. Just fixed it. Most likely, your vacuum control valve solenoid is bad. It's the small grey box that all the vac lines are hooked to.
    Part# is 15-72182 . I got it from AC Direct for $56 shipped.
    If you're pulling it off another car, just follow the vac lines. It's screwed into the blower motor housing. You don't need the rubber manifold that the lines go into, just the grey box.
  1. oil change
    By Will5600 in forum General Tech Discussion
    Last Post: 10-25-2009, 09:54 PM
  2. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
  3. anyone ever change a gt to a gtp
    By e56505 in forum General Tech Discussion
    Last Post: 02-18-2009, 12:12 AM
  4. How soon do you change the oil after........
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2009, 03:56 PM
  5. s/c oil change
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2008, 05:44 PM
