Thread: Need to know remote wire color
Results 1 to 8 of 8
  1. #1 Need to know remote wire color
    Fond du Lac
    I'm hooking up a second aftermarket amp in a 04 gt for a friend and I can't seem to find out which wire going into the monsoon amp is the remote wire/ color. He wants to keep everything else the way it is just louder boom. I don't want to play trial and error with the car cause it could cause too many problems. I tried looking everywhere on the net and can't find help. Could somebody help or point me in the right direction, please
  2. #2 Re: Need to know remote wire color
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    i'm assuming you don't see any blue wires?
  3. #3 Re: Need to know remote wire color
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by NaturallySmashed View Post
    X2 the blue one is ur friend.
    02 GTP with mods 05 GP for DD
  4. #4 Re: Need to know remote wire color
    Ohio
    X3 blue with a white stripe usually
    00 GTP demodded and forsale
  5. #5 Re: Need to know remote wire color
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    the12volt.com is gonna be you best friend. blue is usually the one you want.
  6. #6 Re: Need to know remote wire color
    Fond du Lac
    I wanna tap it into the back of the car where the wire harness runs into the monsoon amp. There is a baby blue wire and I hope that's what you ment by blue wire cause that was the only one I could find, but like I said I didn't want to mess anything up. So I'll try that and if it works, Thanks guys.
  7. #7 Re: Need to know remote wire color
    Medford, NY
    splice into it and test it.. but that's most likely the one.
  8. #8 Re: Need to know remote wire color
    Fond du Lac
    I had to tap into the fuse box to get the remote to work. I tried every wire that went into the amp and it didn't work. But it turned out really good.
  1. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  2. blue remote wire
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 08-26-2009, 11:30 PM
  3. amp remote wire question
    By chrissbee77 in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 11:44 PM
  4. Monsoon Amp Remote Wire and Speaker wiring diagram
    By Thatonepunkrawk in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2009, 07:58 PM
  5. Wiring Remote Wire help!
    By adrenaline54 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2008, 10:49 AM
