hello, I have a 2002 grand prix. I keep failing emmissions and cant figure out why. The code given to me is p0102 and everyone keeps telling me to clean the MAF censor and I did that and the check engine light still wont go off....any ideas??
Is the car stock or any mods such as intake? P0102 DTC means MAF sensor low frequency. Possible causes are blockage at intake screen, vacuum leak at the intake manifold or throttle body, EGR valve flange leak. Also a defective or improperly sealed PCV valve. Try cleaning the throttle body.
i found that online
have you tried putting in a new MAF? sometimes these things just go bad.
try picking a lower mile sensor from a junkyard.. should be cheap
or evan a new one..not sure of cost but atleast this way you can eliminate the possibility of it being a faulty sensor
It is stock. A couple people say try the MAF which is of course expensive so I will be junk yard shopping for the next couple of days! Thanks!
| « Previous Thread | Next Thread » |
| Tags for this Thread |
