Thread: issue caused by volt booster?
Results 1 to 7 of 7
  1. #1 issue caused by volt booster?
    Donating Users Warbeaver's Avatar
    St. Louis
    So, the last several months, I have noticed that my Voltmeter gauge has been acting funny. The volt reading on it has been fine, it's just that the red light keeps going dim for a couple seconds, then getting brighter, then dimming, etc. I messed with wiring, ground, the bulb and still same problem. I also noticed that my driver side fog was flickering a tiny tiny bit. For some reason, i went to my alternator, and took off the zzp stage 1 volt booster.
    Haven't seen the problem since last night.... so, could too high of volts cause this? or is it something defective in teh booster? i was pushing over 14.5 volts using it. without the booster im at 13.9-14.1
  2. #2 Re: issue caused by volt booster?
    Outer Space
    I run the stage 2 volt booster on mine and haven't experienced anything like what you have described.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: issue caused by volt booster?
    St. Louis
    yeah idk...only other thing i can think of ,is the battery. its newer, but the cold cranking amps were lower than my previous battery, (they were out of the right battery and it was a free replacement). I can't even remember how high our cold cranking amps should be?
    its either that, or could it be the alternator?
  4. #4 Re: issue caused by volt booster?
    Charles City, IA
    Gm alternators always surge a little bit. Dont worry about it.
    SMGPFC Two Nipple General
  5. #5 Re: issue caused by volt booster?
    St. Louis
    yeah, im just gonna watch it and see how it goes. its just weird that it quit doing the dimming and fog flickering after i took the booster out. I have heard about some defective ones doing some weird things...
  6. #6 Re: issue caused by volt booster?
    St. Louis
    something i just read on zzp's site:
    "New version has better soldering. Fixes the erratic voltage issues on certain cars. Now compatible with Regal and other 3 wire applications!"
    im wondering how long that has been for?
  7. #7 Re: issue caused by volt booster?
    Jul 2008
    nj
    If there is not a proper connection or the 'signal' wire is not connected, the volts bounce around like you described. I would pull the booster
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  1. Volt Booster
    By impala04ss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2009, 02:04 AM
  2. Stage 1 Volt Booster - Modified
    By Damojo2003 in forum General Tech Discussion
    Last Post: 04-23-2009, 05:11 AM
  3. Where to hook up oil pressure & volt gauge
    By 98GT3800 in forum General Tech Discussion
    Last Post: 02-14-2009, 10:26 PM
  4. small spudder after strt caused by 02 sensor?
    By Onthebrinc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-28-2008, 08:53 AM
  5. 12 Volt Remote
    By mainecrab in forum Audio, Security & Visual Electronics
    Last Post: 06-21-2008, 09:45 AM
