Thread: Window Regulator?
Results 1 to 10 of 10
  1. #1 Window Regulator?
    NE Philly
    Hey I got a to replace the window regulator on the passenger front door. Is there a write up I can follow or can anyone give me some tips to make this job a little easier?
    Thanks
  2. #2 Re: Window Regulator?
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Quote Originally Posted by Lucid Violence View Post
    Thanks
    There really isn't much to it at all. There are two screws in the door panel behind the plugs near the handle. They're a torx head. Pull the panel off, then and unplug all wiring harnesses. There are four bolts holding the regulator in and three holding the motor in. The ones that need to be removed have holes and the ones that can just be loose are slotted. There are two screws up attached to the window glass as well. They can be a challenge to get to. Don't buy a cheap regulator. Spend the extra $ on a good one. The cheap ones are JUNK.
  3. #3 Re: Window Regulator?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by SnowDrift View Post
    those 2 bolts holding the window on the regulator are a breeze to get to if the window is rolled about halfway down
    other then that, i couldnt have said it better. it really is not that hard of a job, and this is not a part you wanna go cheap (ebay) on.
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  4. #4 Re: Window Regulator?
    SE Level Member BlackandSilverGTP's Avatar
    Charleston, WV
    Rock Auto seems to have a number of brands. mine in my front passenger door got a kink in the cable and everything got messed up so i need a new regulator. what brand if any would you recommend that are any good?
    98 GTP - VS Competition Cam, ported and polished M90 eaton w/ 3.1 pulley, ported TB, TOG headers and ported manifold, 2.5" RAT catback w/ Magnaflow mufflers and Magnaflow high flow cat, custom tuned PCM from ZZPerformance
    05 GTO - Stock for now
  5. #5 Re: Window Regulator?
    Apr 2009
    Quote Originally Posted by BlackandSilverGTP View Post
    I seem to remember A1Cardone. It's been a few months, but I've dealt with their parts before and they seem to have good quality parts.
  6. #6 Re: Window Regulator?
    GT Level Member rmcardle3's Avatar
    Houston, TX
    I just recieved all four window regulators (w/motor). Project updates will follow as available.
  7. #7 Re: Window Regulator?
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    are you sure it's the regulator and the switch isn't just dirty?
    i thought my regulator was bad, but turns out it was dirty as sh*t. took apart the switch, cleaned and works like new now.
    http://www.grandprixforums.net/window.php
    if not, then regulator it up.
  8. #8 Re: Window Regulator?
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    for some reason both my car and a buddy of mine had a similiar problem and both came out to be a missing bolt. seems they didnt crank down one of th etwo bolts enouph at the factory and they tend to just come out. at least thats my guess as its a far fetched coincidence that two cars came up with the same problem out of nowhere. check and make sure both bolts r in and tight
  9. #9 Re: Window Regulator?
    Apr 2009
    stockton ca
    i was cheap so i bought what ever was cheap and added the 5% discount code on it at rock auto
  10. #10 Re: Window Regulator?
    Donating Users ptnothere's Avatar
    Vancouver
    GM Pontiac Grand Prix GTP Power Window Motor & Regulator Picture Illustrated Repair Guide - Page 2 of 4
    here you go, write up on how to replace regulator and motor although its easier to just try it by guessing. took me 1 hour to switch out the regulator and motor and then back again because it turns out wasnt the problem
    If its not the switch and its not the regulator/motor. What else could it be that causes the window to not respond 50% of the time when you press the upswitch? Very rarely as well the window will go down by itself and the motor seems to click and tick sometimes...
    I've tried the cleaning the switch job and ive tested with a brand new regulator/motor
    I cant figure it out
  1. Cable on window regulator comes off [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 06-24-2015, 04:44 PM
  2. Window Motor Regulator
    By cutiger80 in forum General Tech Discussion
    Last Post: 12-15-2009, 09:09 AM
  3. Bad window switch or regulator?
    By K7Gixxer750 in forum General Tech Discussion
    Last Post: 11-24-2009, 07:17 AM
  4. Window regulator/motor
    By m1sterb0b in forum General Tech Discussion
    Last Post: 11-20-2009, 01:38 PM
  5. Window Regulator Question
    By cboth686 in forum General Tech Discussion
    Last Post: 04-16-2009, 09:41 PM
