Thread: Custom Intake
Results 1 to 15 of 15
  1. #1 Custom Intake
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    I already have the intake made, but I dont know what size hole to drill for the iat sensor?
  2. #2 Re: Custom Intake
    SE Level Member e6600's Avatar
    Los Angeles
    i think its half inch
    98 grand prix gtp: stock until i fix problems
  3. #3 Re: Custom Intake
    Charles City, IA
    Buy a caliper for about $10. If it is a HAI just let it hang by the filter.
    SMGPFC Two Nipple General
  4. #4 Re: Custom Intake
    Wilkes Barre, PA
    can you explain to me what you mean by that.. sorry i'm a noob with cars.
  5. #5 Re: Custom Intake
    Jul 2008
    Tampa, FL
    he means does the cone go towards the fenderwell, or do you just have a short pipe with the cone hanging in the engine bay?
  6. #6 Re: Custom Intake
    Wilkes Barre, PA
    Oh lol no the pvc pipe is just going where the stock airbox is. I'm putting it in today but i need to drill a hole for the iat and i dont know what size it is to drill
  7. #7 Re: Custom Intake
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    all you need to do is cut the stock factory pipe just after the curly restrictive part and just before the iat and then clamp a filter on that s what i did ill have a pic up in a few...
    2000 Daytona GTP(aka the slow fwd GTO)
  8. #8 Re: Custom Intake
    Nov 2009
    Michigantown, IN
    notice the elbow is the stock elbow all i did was cut the rest of the pipe and clamped the filter on... took me all of 15 minutes and 25 bucks... been on ther for about 3 months...
  9. #9 Re: Custom Intake
    Donating Users Warbeaver's Avatar
    St. Louis
    surely, ur gonna be putting the sensor in something rubber? it won't sit right in pvc pipe. just take a drill bit that 1-2 sizes smaller than the diamater of the iat sensor and do that. the sensor will fit nice and snug
  10. #10 Re: Custom Intake
    Jul 2008
    Tampa, FL
    yeah, get a rubber grommit or something, i'm sure you could find it at home depot or lowes...
  11. #11 Re: Custom Intake
    St. Louis
    i'd drill right where the pvc piping slips under the rubber coupler tubing. you drill through the rubber and pvc pipping. the iat sensor would fit tight in the rubber and you wouldn't need to worry about it sitting perfect in the pvc pipe
  12. #12 Re: Custom Intake
    GTP Level Member apierce1289's Avatar
    United States
    DaytonaGTP, how is that mod you did for the stock intake pipe i want to do the same thing is it any good?
    Also when i remove the factory air box where do i put the PCM and how do i secure it?
  13. #13 Re: Custom Intake
    Oct 2008
    Calgary, Alberta
    some newer (late 90's) gm trucks/vans have the right gromet attached to the iat, in a solid pipe, as well as the older / newer filter minders.
    I have also read that some pcv gromits may work
  14. #14 Re: Custom Intake
    MA
    Quote Originally Posted by apierce1289 View Post
    it should be a good setup. the pcm can lay where the old intake box sat. alot of people say to just lay it there and itll be fine.
    SMGPFC Member #9
  1. Custom FenderWell Air Intake Kit, NEW
    By scottmmckinney in forum General Tech Discussion
    Last Post: 06-17-2009, 01:32 PM
  2. Custom Intake
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 03-24-2009, 04:16 PM
  3. Possibly ducting for a custom intake?
    By Quicklynx in forum General Tech Discussion
    Last Post: 09-04-2008, 11:20 AM
