I guess the best choice is to find good used OEM lights....
i bought a set of those aftermarket headlights of ebay. they look great and installed flawless. one of the corner lights did fog up, but i took it back off and placed a light bead of all weather grease on the bulb harness seal and never had a problem after that. they look awesome! once a month i put some auto wax on the lens to maintain the lesture.
I bought a set. You can't beat them for the money, but they can bounce a little. I never notice any movement while I'm driving, though. They will only fog up if you let moisture get inside them. There's a white plastic drain plug on both the headlight and parking light. If you ever get moisture in them, remove and empty the water if it's a lot, then leave the plug out for a few days. They will dry out. I never gave a thought to swapping out the original bracket. Awesome idea! I just wish that I hadn't tossed the original headlights.
