Thread: Gen 5 or ported gen 3
Results 1 to 11 of 11
  1. #1 Gen 5 or ported gen 3
    Minnesota
    I want to either look into getting a gen 5 supercharger or port my gen 3. what are the major differences? and how hard is it to port it? thaankks
  2. #2 Re: Gen 5 or ported gen 3
    GTP Level Member KwazrollinZ28GTP's Avatar
    FLINT/michigan
    well they say if both are stock Gen5 has about 20 extra horses, But when you port your Gen 3 its about even with the Gen5. That's from what I've heard.
    I ported my Gen3 Blower and stuck on a 3.4 pulley and the thing whines and rips hard.
    Also You need to rig a Gen3 throttle body to fit the Gen5 Because The throttle bodys are different. So your looking at around over 300-400 for the Gen5 blower vs 100 or so for a Gen3 then port it.
    and a different Intake manifold is also required.
    I ported my intake and supercharger when i had them apart and out of the car.
  3. #3 Re: Gen 5 or ported gen 3
    to justify wasting money on a genV you need a decent setup to go with it. youll only gain a bunch from it when youre already pretty heavily modded. for a normal person running a 3.4 and headers its a waste of money.
  4. #4 Re: Gen 5 or ported gen 3
    Troy OH
    ^^^exactly. you can only handle so much boost. if a genIII can give you that boost, then there's no need for a genV.
  5. #5 Re: Gen 5 or ported gen 3
    Minnesota
    ok thats what i thought thanks eventual i wanna port my genIII, if i did that i have to por the lim as well right?
  6. #6 Re: Gen 5 or ported gen 3
    Portland Oregon
    Porting and smoothing the inlet can be done. You can port the outlet for some gains. If you plan on intercooling then while you're in there go ahead and remove the h-bar and machine the LIM.
  7. #7 Re: Gen 5 or ported gen 3
    Minnesota
    maybe down the road il be looking into ic but for now im not. does it hurt to remove the h bar without ic
  8. #8 Re: Gen 5 or ported gen 3
    Portland Oregon
    I wouldn't say it'll hurt. If you do that you may as well machine the LIM to match. Go to zzperformance.com and look at a pic of their machined LIM and you'll know what I mean. Also since there will be more volume added under the blower with the area opened up you'll probably have to pulley down to maintain the same level of boost.
  9. #9 Re: Gen 5 or ported gen 3
    Putting a Gen V on by itself is like adding an intercooler. It's a great early mod.
    Porting a Gen 3 is like getting a bandaid when you cut your leg off. Huge difference. I've done a lot of both being an installer. The tuning, power and changes overall from a Gen V far outweight any porting done to Gen 3's.
  10. #10 Re: Gen 5 or ported gen 3
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    yeah but the genv sounds so much better and its more efficient... to an extent i guess. i suppose if youre mildly going to mod i would advise no genv but if you really want to work your engine a genv is a good idea.
    2000 Daytona GTP(aka the slow fwd GTO)
  11. #11 Re: Gen 5 or ported gen 3
    With Gen V pricing being pretty good these days. I'd suggest it.
    Lower temps = less KR. Why pump heat into your motor when you can pump in cool air?
    I ported, I polish, I learned everything about the hardest ways possible.
    Take a ported Gen 3 and a Gen V. Run them the same and then pop both hoods. Put your hand on the Gen V. warm, you could keep your hand on it..but not going to burn you. Gen 3... can't keep your hand there, it would burn you.
  1. ported lim
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-19-2010, 07:42 AM
  2. Ported TB?
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2008, 05:32 PM
  3. Ported LIM?
    By Sabrewings in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2008, 03:02 AM
