Thread: Window malfunction
Results 1 to 3 of 3
  1. #1 Window malfunction
    CT
    Well the drivers rear window is broken on my car. From what I can tell without removing the panel is that its still on its track and that the motor is working from what I can hear inside the door. What I believe is that whatever connects the window to the motor just came off. Could be a bolt or what not but I do not know as I've never really taken a door apart to repair this. Does anyone have a little insight as to whats in there?
  2. #2 Re: Window malfunction
    Outer Space
    The cables broke or the plastic tabs holding the cable did... you need to get a used window regulator. The door panel is held on by 2 screws (right by the door handle.. they have caps over them..pry em off.) ... then the rest of the panel is held on with push pins. Start at the bottom and gently pry around.
    The regulator is only held on with like 4 bolts.
    You can get used one for like $50 bucks either from Morad or zzp. I have replaced 3 of mine so far.
    LINK: http://cgi.ebay.com/ebaymotors/97-03...Q5fAccessories
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Window malfunction
    CT
    Ok I'll take it off to just verify. That really blows that it broke as I never use that window and it just one day was falling down. At least its not that hard to get to and cheap.
  1. Window fog. How to get rid of?
    By Toofastgs in forum General Tech Discussion
    Last Post: 12-10-2013, 12:49 PM
  2. P0410 Secondary Air Injection System Malfunction
    By NaturallySmashed in forum General Tech Discussion
    Last Post: 07-09-2010, 11:36 PM
  3. NEED HELP: Speedometer malfunction and car jerks
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-11-2010, 08:39 PM
  4. window help??
    By Kizorm in forum General Tech Discussion
    Last Post: 02-27-2010, 11:02 PM
  5. Window Problem (Front Driver Side Window)
    By trogdor007 in forum General Tech Discussion
    Last Post: 06-03-2009, 09:22 PM
