Thread: Could THIS Be Causing All of the Engine Fires?
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
  1. #41 Re: Could THIS Be Causing All of the Engine Fires?
    Oct 2011
    San Jose, CA
    The O'Reillys pack is already mentioned and pictured at the beginning of this link
  2. #42 Re: Could THIS Be Causing All of the Engine Fires?
    Texas
    Quote Originally Posted by relivenyouth View Post
    txslow6, do you mean replacing the entire line with braided stainless?
    Yes. There is a write up in the how to section.
    85 Corvette
    01 TA
    03 Z06
  3. #43 Re: Could THIS Be Causing All of the Engine Fires?
    Oct 2011
    San Jose, CA
    All, found the correct Viton o-rings for the fuel line quick disconnects on the supercharged Grand Prix. They are working fine so far, no leaks! Bought them at AutoZone, looks like O'Reily's also carries. Call ahead, may have to special order. Recommend also buying the mechanics pick set (dental like angled pick, very helpful with removal)
    Dorman #800-013 (2 @ 5/16 & 3/8)
    http://www.dormanproducts.com/p-30428-800-013.aspx
    Good replacement "how to" is found in this forum on this link:
    http://www.grandprixforums.net/injector_oring.php
  4. #44 Re: Could THIS Be Causing All of the Engine Fires?
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Nice to know this was a problem for others too.I actually had fuel in my lower intake pockets when i changed mine That was two years ago when it only had 208k on it...lol. That rear connect just gets so much movement from the motor rocking.BAD DESIGN
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  5. #45 Re: Could THIS Be Causing All of the Engine Fires?
    GT Level Member sic6's Avatar
    san marcos, tx
    I used the dorman nylon lines. Part # 800-58.
    97 GTP
  6. #46 Re: Could THIS Be Causing All of the Engine Fires?
    Donating Users garagedoorman's Avatar
    Jan 2009
    north georgia
    Man glad I came across this. Bumping for a nice weekend project
    Great info
  7. #47 Re: Could THIS Be Causing All of the Engine Fires?
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    If you have the Harbor Freight O-ring assortment those are fine too, since the kit contains both sizes. Nitrile O-rings are OK to use with fuel also, see this article on using them in carburetors.
  8. #48 Re: Could THIS Be Causing All of the Engine Fires?
    i found a set of assorted vitan O rings, they are fuel rated. the black ones are not, they will fail over time. found them at napa.
  9. #49 Re: Could THIS Be Causing All of the Engine Fires?
    Dec 2008
    ****'s Creek
    I got the $10 Viton o-rings and I must have scratched the inside of the connector....it leaks no matter I do. Going to plan B with the Dorman nylon line that I can splice in.
  10. #50 Re: Could THIS Be Causing All of the Engine Fires?
    does it click when you push it on, then move with no fuel pressure on the line yet, like back and fourth? its should.
    you may have the wrong O ring in there, mine fell apart when i took them out, it was pretty hard to match up the new ones. i used the wrong larger one the first time around.
    the smaller one was about the size of the rail end too.
  11. #51 Re: Could THIS Be Causing All of the Engine Fires?
    Dec 2008
    ****'s Creek
    Dorman 800-059 is the rear line, the splice was a ton easier than trying to perform micro-surgery on those O-rings....just a simple barb fitting connects the new line to the old.
  12. #52 Re: Could THIS Be Causing All of the Engine Fires?
    SE Level Member lostscout's Avatar
    Sep 2014
    Cold Lake Alberta Canada
    my theory on why these cars burn...the cat plugs up, forcing extra hot exhaust up thru the stovepipe, melting the UI and the plastic gas line right on top of the manifold
  13. #53 Re: Could THIS Be Causing All of the Engine Fires?
    Mar 2017
    Internet
    Sorry.. I don't buy it.
    Especially since GM changed the stove pipe design from having almost no clearance to the manifold to having a lot. and the only harm that did was the heat cycles of the plastic manifold would cause the manifold to crack quicker. Which..in turn allowed coolant to fill the intake of the motor. No fire from that.
  1. Heavy stutter under boost, but no mis-fires
    By 007 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2010, 12:46 AM
  2. What's causing this?
    By BwolfGT in forum General Tech Discussion
    Last Post: 10-02-2009, 04:57 PM
  3. 97 fires but wont run.
    By clh97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-20-2009, 10:08 PM
  4. What is causing my MAF to go out?
    By MartinTD in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2009, 04:33 PM
  5. Hub Assembly causing thunk?
    By Deezul_AwT in forum Tires & Wheels
    Last Post: 03-28-2008, 07:36 PM
