Thread: Fluctuating gas gauge problem!
Results 1 to 14 of 14
nikkigpgt00 Fluctuating gas gauge problem! 04-04-2010, 06:16 PM
rocafella2032 Re: Fluctuating gas gauge... 04-04-2010, 06:27 PM
DaytonaGTP Re: Fluctuating gas gauge... 04-04-2010, 06:29 PM
nikkigpgt00 Re: Fluctuating gas gauge... 04-04-2010, 06:45 PM
DaytonaGTP Re: Fluctuating gas gauge... 04-04-2010, 06:50 PM
DaytonaGTP Re: Fluctuating gas gauge... 04-04-2010, 06:56 PM
nikkigpgt00 Re: Fluctuating gas gauge... 04-04-2010, 07:05 PM
SuperSport Re: Fluctuating gas gauge... 04-04-2010, 08:54 PM
nikkigpgt00 Re: Fluctuating gas gauge... 04-04-2010, 10:03 PM
SuperSport Re: Fluctuating gas gauge... 04-04-2010, 10:46 PM
1LoudGrandPrix Re: Fluctuating gas gauge... 04-05-2010, 10:31 AM
SuperSport Re: Fluctuating gas gauge... 04-05-2010, 02:36 PM
RICE KILLER Re: Fluctuating gas gauge... 04-10-2010, 12:45 AM
sic6 Re: Fluctuating gas gauge... 04-11-2010, 04:06 PM
  1. #1 Fluctuating gas gauge problem!
    GTX Level Member nikkigpgt00's Avatar
    MI
    What could be causing my gas guage to fluctuate? I will fill it up to say a half tank, I pull in my driveway and it will go up to saying its Full. Then next time I leave it will go down to half, back to full and then down to empty before it goes back to where its supposed to be. Any ideas what my problem would be? I have an extended warranty that came with the car when I bought it but its pretty picky on what it covers. I was hoping to get some ideas before having to take it in.
  2. #2 Re: Fluctuating gas gauge problem!
    Norristown, PA
    Is your driveway flat? or slanted?
    My gas gauge is acting up to, it goes down when im in park or not moving.
  3. #3 Re: Fluctuating gas gauge problem!
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    Quote Originally Posted by nikkigpgt00 View Post
    bout 99% sure its yur sending unit for the fuel. its in your tank and holds your pump.
    2000 Daytona GTP(aka the slow fwd GTO)
  4. #4 Re: Fluctuating gas gauge problem!
    MI
    It doesnt just do it in the driveway though. The other day it said I had a quarter tank. I drove a ways then the fuel light came on. A few more miles it went off. It went on and off for awhile. Its like it has a mind of its own. Im just concerned because it makes it hard to tell how much gas I actually have.
  5. #5 Re: Fluctuating gas gauge problem!
    Nov 2009
    Michigantown, IN
    thats because the float on your sending unit is giving false readings. ive run into this lots of times and almost everytime its the sending unit. its possible that the gauge is faulty. youve got 2 options. replace the unit or fill your tank up and start using your trip meter to tell you how much youve drivien on a tank...
  6. #6 Re: Fluctuating gas gauge problem!
    Nov 2009
    Michigantown, IN
    Quote Originally Posted by DaytonaGTP View Post
    i just found this it might help you...
    http://www.grandprixforums.net/f17/f...ing-17836.html
  7. #7 Re: Fluctuating gas gauge problem!
    MI
    Ive tried the mileage thing but I dont always have enough money to fill my tank everytime I need gas. I think I may have a broken tie rod so I guess as soon as I can get my car in for that I will ask about the gas gauge. What a pain!
  8. #8 Re: Fluctuating gas gauge problem!
    GTP Level Member SuperSport's Avatar
    Michigan
    If you take it to a shop they will try to convince you that the whole fuel pump assembly needs to be swapped out. ($$$)
    Its just the fuel sending unit that is dead.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  9. #9 Re: Fluctuating gas gauge problem!
    MI
    Ok for someone not good about mechanics what options do I have? Im good with modding but not this stuff
  10. #10 Re: Fluctuating gas gauge problem!
    Michigan
    What I meant was, if you take it to a shop, they will tell you the whole fuel pump and sending unit need to be changed, which would be 500 bucks plus labor, when the only thing that needs to be changed is the float that clips to the side of the fuel pump unit which is only 90.
    If youre good with modding then its not that bad of a job to do yourself. Im not good with modding and I changed the sending unit myself. Took me 30 mins.
    Also if you take it to a shop, they will also insist on dropping the gas tank when there is an access panel in the trunk to make the job 1000 times easier.
  11. #11 Re: Fluctuating gas gauge problem!
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    what is the part number?
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  12. #12 Re: Fluctuating gas gauge problem!
    Michigan
    Part number for the Sending Unit: 89060197
    Picked up mine from GMPartsDirect.com
  13. #13 Re: Fluctuating gas gauge problem!
    SE Level Member RICE KILLER's Avatar
    st. paul mn
    my 97' olds 88 used to do the same thing it was just a dirty connection from the float unit to the gauge try cleaning the connection before you go out and spend all that money
  14. #14 Re: Fluctuating gas gauge problem!
    GT Level Member sic6's Avatar
    san marcos, tx
    You could also use dorman part number 911-008.https://www.dormanproducts.com/cgi-b...1&vtime=61424#
  1. Engine Coolant Temp Fluctuating
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 07-29-2013, 04:33 PM
  2. Another Fuel Gauge Problem
    By SilverGT in forum General Tech Discussion
    Last Post: 06-13-2012, 09:45 PM
  3. gauge problem
    By 1LoudGrandPrix in forum General Tech Discussion
    Last Post: 03-17-2010, 09:11 AM
  4. Fuel Gauge Fluctuating
    By UTfanatic80 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-13-2009, 05:21 PM
  5. gas gauge problem
    By reinke in forum General Tech Discussion
    Last Post: 10-20-2008, 07:20 PM
