Thread: Antifreeze Pooring Out Of 2001 GP 3.8
Results 1 to 5 of 5
  1. #1 Antifreeze Pooring Out Of 2001 GP 3.8
    Iowa
    I can't see exactly where this is coming from. It appears to be dripping down onto the rim of the oil pan on the drivers side then on down. At first glance it would look like it is coming out of the pan itself but the quickly you can tell that it is dripping from above it.
    Anyone have any ideas what is right above the that area of the pan that would have antifeeze flowing through or flowing over it? Is there a sending unit down there? By-Pass hose of some sort?
    Thanks.
  2. #2 Re: Antifreeze Pooring Out Of 2001 GP 3.8
    Apr 2009
    stockton ca
    temp sensor on the lim maybe the thermostat gasket
  3. #3 Re: Antifreeze Pooring Out Of 2001 GP 3.8
    SE Level Member RICE KILLER's Avatar
    st. paul mn
    t-stat gasket for sure get a new gasket clean the housing and where it meets the lim use some rtv and button up all the hose connections see if that works
  4. #4 Re: Antifreeze Pooring Out Of 2001 GP 3.8
    Outer Space
    wipe it all off... and then start the car and watch discovery channel style... you will find it.
    02 GTP 13.6 @ 100mph - SOLD
  5. #5 Re: Antifreeze Pooring Out Of 2001 GP 3.8
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    could also be the tb gasket.
  1. burning antifreeze
    By gearjammer79 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-02-2009, 01:29 PM
  2. antifreeze leak..
    By bowtechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:36 PM
  3. Antifreeze leak...
    By bowtechguy in forum General Tech Discussion
    Last Post: 03-23-2009, 07:24 AM
  4. Smelling antifreeze
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 11:06 PM
  5. Leaking Antifreeze
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 08:13 PM
