Thread: burning antifreeze
Results 1 to 9 of 9
  1. #1 burning antifreeze
    Saint Catharines, Ontario, Canada
    Hi. was wondering if any one can help with this problem I have.. my 97 gp gt is burning a fair bit of antifreeze.. I notice it blows a bit of white smoke from the tail pipes but not alot. Ive been keeping my eye on it and the antifreeze is not going into the oil so I know its not the head gasket and the oil is not going into the rad so i figured its not the intake gaskets.. Does any one have any suggestions. Thanks
  2. #2 Re: burning antifreeze
    SE Level Member PowerStroker's Avatar
    Minnesota, Eh?
    How do you know that the antifreeze isn't going into the oil? I've always been curious to know how people KNOW these things and they're so sure of it...
    I think I know what's wrong with your motor, but I'm just curious how you know
    2003 F-350 7.3L Powerstroke, hybrid (burns diesel and rubber ), lots of mods, and gets 22.5 mpg!
    2000 Grand Prix SE 3.1L
  3. #3 Re: burning antifreeze
    Quote Originally Posted by PowerStroker View Post
    The oil is not milky after being run. That's how you can tell.
    The 3.8L doesn't usually suffer head gasket issues. The L36 or naturally aspriated 3.8L suffers from a poorly designed upper intake manifold or UIM. The EGR gasses flow through the (plastic) manifold, on the other side of the EGR passage is the ports for the coolant to the TB. The plastic cracks, LIM fills with coolant and soon you are burning it or hydrolocked.
    I suggest changing the LIM gaskets while the UIM is off.
  4. #4 Re: burning antifreeze
    Oct 2008
    Northern Illinois
    UIM and/or head gaskets. YOu pretty much just described exactly what happens when head gaskets fail.
  5. #5 Re: burning antifreeze
    St. Louis Mo.
    Moved to correct section
    James Shafer
    St. Louis MO
  6. #6 Re: burning antifreeze
    land o lakes FL
    yea i had the same thing going on with my car for like 3 months, and then gess what my head gasket went. im going to say its you head gaskets going.
  7. #7 Re: burning antifreeze
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    a bad radiator can cause your coolant and transmission fluid to mix, since the transmission uses the radiator too. how does your transmission fluid look?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  8. #8 Re: burning antifreeze
    Wausau, WI
    Quote Originally Posted by Jakegday View Post
    this would not explain white smoke coming out of the exhaust, but a blown head gasket would.
  9. #9 Re: burning antifreeze
    Nov 2008
    Fremont Nebraska
    meh, true, i was just throwing in my 2 cents since he stated he "knows" its not the head gasket
  1. antifreeze leak..
    By bowtechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:36 PM
  2. Antifreeze leak...
    By bowtechguy in forum General Tech Discussion
    Last Post: 03-23-2009, 07:24 AM
  3. Smelling antifreeze
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 11:06 PM
  4. Thats it, Im burning the ***** down
    By Toofastgs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2008, 08:52 AM
  5. Leaking Antifreeze
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 08:13 PM
