I'd say a gummed up throttle body / idle air valve. pretty easy to do and at 100K it probably needs it.
I use napa wires with no problem -- others say stock. either way.I typically use NAPA silicone wires
no, probably just drop the pan and do the filter would be fine.Final question:
Since the car has just rolled 100k miles, I assume it's recommended to have the tranny flushed.
no spin ons, and no drain on the pan... but you shouldn't take it to a shop either. get yourself a good filter and some Dex6 and you're good to go. I'd do it myself just to make sure the fluid is right.Are there spin-on filters and a trans dain hole, or should I take this car to a shop?
good luck.
