Thread: DIC message "check gas cap"
Results 1 to 10 of 10
  1. #1 DIC message "check gas cap"
    SE Level Member Piggy's Avatar
    Cincinnati, Ohio
    exactly what it says... my gas cap has never really been too tight but never sent a message to the dic... ne ideas to clear and keeep it cleared?
  2. #2 Re: DIC message "check gas cap"
    get a new gas cap
  3. #3 Re: DIC message "check gas cap"
    Willoughby, Ohio
    the seal is bad on the cap, you get get a locking one for like $15. thats what i did
  4. #4 Re: DIC message "check gas cap"
    SE Level Member habeba86's Avatar
    Elmwood/Peoria Ill
    weird.....when I forgot to put mine back on when I got gas, it didnt do anything for a couple days, then threw an evap code and the check engine light came on.
    10 Z1000
    00 gtp..few goodies
    97 XJ
    98 T/A cammed/stalled/spray *sold*
  5. #5 Re: DIC message "check gas cap"
    West Side Michigan
    My dad's GP and some other people I know with their 04+ GP's have the same problem. I think it's a glitch or something. My dad ignored it and it went away. He replace it a couple times and nothing happened. I actually think it was the sensor that went bad.
  6. #6 Re: DIC message "check gas cap"
    Scan it and see what code its throwing.
  7. #7 Re: DIC message "check gas cap"
    Donating Users dirtmaster88's Avatar
    Sheboygan, WI
    if its not a gas cap its more than likely a solenoid valve (spelling?). Had this problem on my 04 compg and it only went away after replacing that. Dealer fixed it for like 20 bux or something
    2004 GTP CompG - 3.6" ZZP MPS, K&N CAI, 180* Tstat, SSAC Headers, ZZP Flex, high flow cat, borla exhaust, DHP/danthurs tune, AL104s, ZZP Wires, alt re-wire, slotted/drilled rotors, 35% tint, alpine amp + sub
  8. #8 Re: DIC message "check gas cap"
    Michigan
    My car shows the check gas cap on the DIC every once in a while. When I pump gas I have to do it slowly or the pump will shut off. Has anyone had this problem? Is the Vent solenoid bad? ANy help apprecitated.
  9. #9 Re: DIC message "check gas cap"
    London Ontario
    I have the same issue as we speak. I switched gas caps with our 2nd GP and it still errors. It also causes the check engine light to illuminate. Chances are it's really not the gas cap at all. It's an 06 GP Supercharged and very annoying to have something wrong with my baby. Any advice on an easy fix.
  10. #10 Re: DIC message "check gas cap"
    Charles City, IA
    You have an evap leak, have a shop hook it up to a smoke machine and find the leak replace the part.
    SMGPFC Two Nipple General
  1. "CHECK GAGES" And Battery Light?
    By K7Gixxer750 in forum General Tech Discussion
    Last Post: 11-22-2009, 04:16 AM
  2. Check out this "CUSTOM" car
    By David in forum Off Topic Discussion
    Last Post: 08-17-2009, 10:04 AM
  3. Check out this "SHOW CAR"
    By BoostedComp in forum Off Topic Discussion
    Last Post: 07-27-2009, 12:45 AM
  4. "Reduced Engine Power" message
    By TomDaBomb2u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2009, 11:00 PM
  5. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
