Thread: The alt rewire mod actually DOES increase fuel mileage!!
Results 1 to 20 of 114
  1. #1 Re: The alt rewire mod actually DOES increase fuel mileage!!
    GT Level Member bayareagtp's Avatar
    Milpitas , Ca.
    since the install of the alt. rewire and stage 1 volt booster i have notice a .4 miles per gallon increase in gas mileage . i will post up after my next fill up to let you know if it changes any .
    1998 GTP , 3" down pipe w/cat , u-bend delete , full 3" exhaust w/ magnaflows , no resonator , powerslot front rotors , Overkill PCM , Overkill FWI , 180* t-stat , 1* colder plugs , alt. re-wire , alt. stage 1 booster . 215 whp and 238 torque .
  2. #2 Re: The alt rewire mod actually DOES increase fuel mileage!!
    GT Level Member GreenNirvana101's Avatar
    Feb 2008
    Wisco
    I installed the rewire and the stage 1 booster as well... today I filled up to find the actual mileage... +1.2 mpg increase. Not bad at all! Especially at $4.05 a gallon!
    Former Camaro muscle and DSM turbo owner - now moving into the GTP Supercharged world!
    1997 GTP - STOCK.... for now
  3. #3 Re: The alt rewire mod actually DOES increase fuel mileage!!
    SE Level Member yourTVlies's Avatar
    Hey all -
    I don't mean to resurrect this thread without warrant - but I was thinking about doing the alt rewire for kicks (and an increase on fuel economy if I'm lucky). And I was curious about the the necessity for fusing this. I've done some searches and it seems as though some folks have been a bit concerned over this - but if my line of thinking is correct - an additional fuse on the rewire shouldn't be needed, as the stock wire doesn't have a fuse either - correct?
    Thanks.
  4. #4 Re: The alt rewire mod actually DOES increase fuel mileage!!
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by yourTVlies View Post
    Hey all -
    Thanks.
    Unless I looked at my GM manual incorrectly this "alt rewire" does bypass a fusible link. fwiw, I still have mine installed w/o a fuse, but have a feeling it's not the smartest thing.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  1. high mileage trans issues
    By 01whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2008, 08:23 AM
  2. Headlight rewire
    By dsgtp in forum Visual/Body Modifications
    Last Post: 12-17-2007, 11:31 PM
