Thread: Straight pipes sound bad, loud ticking when accelerating
Results 1 to 17 of 17
  1. #1 Straight pipes sound bad, loud ticking when accelerating
    Jul 2010
    Chicago
    Hi just cut the mufflers off my gt and at first it sounded great. Had a nice deep roar in park and reving up to the limiter. Put it in drive and go around the block and it sounds absolutely horrifying. In low rpm's it's sounds decent but approach 3000 and there is an obnoxious loud ticking clanking somthing noise that I can't stand. It sounds like its coming from the front end but I really can't be sure. I just clamped the straight pipes on right where I cut off the mufflers. Should I even bother welding the pipes on to se if a good seal would stop this ticking? Or just have the mufflers welded back on? Btw I had my resonator removed a while back I don't know if this makes a difference.
  2. #2 Re: Straight pipes sound bad, loud ticking when accelerating
    Florida
    Your exhaust is jacked up lol.Get a nice long glasspack/resonator put it where your old one was. And i feel you on the bad sound with no mufflers i have the same setup. But as far as the ticking goes it sounds like you have an exhaust leak somewhere; find it, fix it. Welding is best.
  3. #3 Re: Straight pipes sound bad, loud ticking when accelerating
    Pennsylvania
    lol. "loud ticking clanking" is a pretty perfect description of a 3800. You've done a silly thing, sir.
  4. #4 Re: Straight pipes sound bad, loud ticking when accelerating
    Re-install mufflers.
  5. #5 Re: Straight pipes sound bad, loud ticking when accelerating
    No resonator?
    No mufflers?
    Oh
    fuklingchristsakes
  6. #6 Re: Straight pipes sound bad, loud ticking when accelerating
    St. Louis
    Because racekar?
  7. #7 Re: Straight pipes sound bad, loud ticking when accelerating
    Jul 2010
    Chicago
    How much u think a shop would charge to just weld my old mufflers back on?
  8. #8 Re: Straight pipes sound bad, loud ticking when accelerating
    Cost all depends on the shop/guy. If you let him laugh at you, he will likely cut you a break. Me..i'd go in and say "I've made a big mistake, please help me"
  9. #9 Re: Straight pipes sound bad, loud ticking when accelerating
    sympathetic shops are are hard to come by. but it does happen.
  10. #10 Re: Straight pipes sound bad, loud ticking when accelerating
    Mar 2012
    Minnesota
    Could try seeing how a large resonator makes it sound, could help with getting rid of the high rpm rasping. Just my .02
  11. #11 Re: Straight pipes sound bad, loud ticking when accelerating
    i rode for a few days with a cat and res and no muffler, it wasn't to bad, but it got old fast.
  12. #12 Re: Straight pipes sound bad, loud ticking when accelerating
    GT Level Member SleeperGS's Avatar
    Dec 2010
    Cincinnati, Ohio
    Do we not need some sort of back pressure?
  13. #13 Re: Straight pipes sound bad, loud ticking when accelerating
    Pennsylvania
    Quote Originally Posted by SleeperGS View Post
    Back pressure's for suckers.
  14. #14 Re: Straight pipes sound bad, loud ticking when accelerating
    ~1psi is normally sufficient for proper scavenging. you need to worry about velocity, which too big will ruin. dont worry about back pressure.
  15. #15 Re: Straight pipes sound bad, loud ticking when accelerating
    Topeka, KS
    We don't have v8's and our 3800's don't sound like a V8 with any exhaust. Why does everyone post, I took all the mufflers off my car and Rev'd to the limiter.
    Ugh...
    Re-install some sort of muffler and put in a 30" glasspack where the res was.
  16. #16 Re: Straight pipes sound bad, loud ticking when accelerating
    Jul 2010
    Chicago
    So the loud ticking noise was my effing flex pipe on my downpipe is broken. Will just be upgrading to the zzp downpipe with magnaflow cat and u-bend delete. Just had my mufflers welded on today hoping to hear a normal sound again but nope.
  17. #17 Re: Straight pipes sound bad, loud ticking when accelerating
    Topeka, KS
    Ya any ticking sound is an exhaust leak.
  1. Loud ticking noise on acceleration
    By cameron92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2012, 07:48 PM
  2. gurgle / running liquid sound when accelerating
    By chuy09 in forum 04+ Specifics
    Last Post: 02-17-2012, 07:09 PM
  3. Dual Straight Pipes
    By pontgp02 in forum General Tech Discussion
    Last Post: 07-18-2011, 11:10 AM
  4. Sloshing sound while accelerating
    By Quicksilver_GP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2009, 07:45 PM
  5. Straight Pipes on GTP?
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2008, 08:12 PM
