Thread: The alt rewire mod actually DOES increase fuel mileage!!
Results 1 to 20 of 114
  1. #1 Re: The alt rewire mod actually DOES increase fuel mileage!!
    St. Louis Mo.
    I am redoing my Big 3 rewire using 2 0/1ga wires for the grounds from the Alt bracket to the strut tower and from the Neg Terminal on the battery to the engine chassis and I am using a 0/1ga wire from the Alt to the fuse box. The only difference from you Josh is that I am going with this.....
    KnuKonceptz High Current In Line 0 Gauge Fuse Holder - eBay (item 220320941701 end time Feb-27-09 09:34:14 PST)
    Why?
    Well ever since this topic was started I did my original Big 3 without any circuit protection from the Alt to the Fusebox. After reading your posts and Syn's posts about adding "protection" between the Alt and the Fusebox I agreed that was the "safe" thing to do. However my path lead me in the direction of using the circuit breaker I listed above. Mostly for the fact that the Stinger circuit breaker you posted has a higher fail rate over time due to wear on the circuit breaker.
    I went to several different car audio forums and asked them and they echoed the same thoughts on the issue. They all agreed they are great in their form, but they just simply wear down over time. Of course everyone had different opinions on the varying degrees on how much wear actually occurs, but it got me thinking about it. So I decided to with this design of circuit breaker instead of the flip switch type you are currently using.
    The other benefit of the one I listed is that it runs three seperate fuses, all equal in size totalling 120amps. Just a tad over what our Alts can produce, but not to much to cause an overload if there was a spike or breakdown in the Alt. The concept of the 3 fuse design is to allow more current to pass through efficently without sacrificing its circuit breaking capabilities.
    Hopefully in the next week or so when the new circuit breaker arrives I will post up pictures of the complete redo of my Big 3.
    James Shafer
    St. Louis MO
  2. #2 Re: The alt rewire mod actually DOES increase fuel mileage!!
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by GeddyLee View Post
    ...However my path lead me in the direction of using the circuit breaker I listed above...
    You are showing a fuse, not a circuit breaker. If you want to go that route, get a mega-fuse. They are designed for alternators; you will find them on Ford vehicles quite often, actually. There is nothing wrong with using a fuse instead, I just happen to prefer a circuit breaker when it costs the same.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  3. #3 Re: The alt rewire mod actually DOES increase fuel mileage!!
    St. Louis Mo.
    Quote Originally Posted by JoshMcMadMac View Post
    Sorry for the mixed up wording I wonder if that mega fuse will work in the fuse holder I ordered? I'll have to find out once it arrives.
    Thanks again for clearing that up sir
    James Shafer
    St. Louis MO
  4. #4 Re: The alt rewire mod actually DOES increase fuel mileage!!
    Waynesboro, PA
    It will not.
    Mega Fuse:
    Mega Fuse Holder:
  5. #5 Re: The alt rewire mod actually DOES increase fuel mileage!!
    Waynesboro, PA
    Also, I do not know that I buy into this:
    There is a reason we run single, large wires in place of several smaller wires, and there is a reason every normal fuse out there is a single blade. I would stick to things that are tried-and-true for an application...which is why I suggest the mega fuse.
  1. high mileage trans issues
    By 01whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2008, 08:23 AM
  2. Headlight rewire
    By dsgtp in forum Visual/Body Modifications
    Last Post: 12-17-2007, 11:31 PM
