Thread: heater squeak
Results 1 to 9 of 9
  1. #1 heater squeak
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    Hey, I searched and had no luck, can anybody show, or explain how to pull out the heater blower motor, Mine has a squeak when it is running, and I wanna pull it apart to see if I can fix it, or if I need to replace it. do you gotta go from the engin bay? or does it come out from under the dash? or do I gotta pull the dash to get at it? thanks
  2. #2 Re: heater squeak
    Feb 2009
    Red Deer AB
    anybody?
  3. #3 Re: heater squeak
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    Crawl under the passenger side dash, you'll see the 3 bolts you need to remove it... Been awhile, so I'm only going by memory...
  4. #4 Re: heater squeak
    Willoughby, Ohio
    yes there is 3 bolts in a triangle, unscrew those and unplug the wire harness, and there is a tube that wil stay attached to the motor, and it will come right out
  5. #5 Re: heater squeak
    Feb 2009
    Red Deer AB
    Awsome, thanks guys!
  6. #6 Re: heater squeak
    Feb 2009
    Red Deer AB
    Has anybody tryed taking the motor off the blower itself? I pryed a little, but I dont want to break it, it still works fine, just FUKING SQUEAKS when its on. I pulled it out today, and figure that the squeak IS coming from the motor, but there seems to be no way to get at it. ???
    98' GTP, 18's, BMR Adjustable Forward & Rear Lateral Arms, BMR Tubular Trailing Arms, Intense PCM, CAI, drilled rotors, 5% Tint all around
  7. #7 Re: heater squeak
    Feb 2009
    Red Deer AB
    no?
  8. #8 Re: heater squeak
    Willoughby, Ohio
    i got a used one for 30 bucks and i have the old one sitting in my room. i havent takin it apart but i would like to do so one day so i can try to fix it to possibly have a backup. idk what would actually be wrong internally tho
  9. #9 Re: heater squeak
    Feb 2009
    Red Deer AB
    ya, I found a junkyard with one for $40, but the guy has gotta take it off, and I was busy all weekend. I dont really like this junkyard setup... I would rather go get the parts myself, and I could check the car out for other parts. This guy says he has a couple of GP's but I call and ask him stuff, and his answer is " I will half to check" If you wanna sell parts, maby you should figure it out.... and have an answer when I call you back! even when I call back he still hasent done sh!t. I would much rather go somewhere else, but there is not many 97-03 GP's in the scrapyards around here.
  1. Right front Squeak
    By gvandal in forum General Tech Discussion
    Last Post: 12-03-2009, 07:37 AM
  2. Got a squeak that won't go away...
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 10-02-2009, 06:12 PM
  3. Squeak when going over Big/Speed Bumps
    By ravi in forum Brakes/Suspension/Chassis
    Last Post: 08-19-2009, 02:01 PM
  4. Perpetual belt squeak
    By Coogles in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2008, 09:07 AM
  5. 3.4 pulley squeak
    By pacoflyer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-28-2008, 12:15 PM
