Thread: Boost guage installed..took every bit of 15 min..
Results 1 to 20 of 31
  1. #1 Boost guage installed..took every bit of 15 min..
    SE Level Member Boosted02GTP's Avatar
    Feb 2009
    Long Grove IL.
    So I went pepboys and got a cheapo $28, 20psi gauge. About 7' of small tubing and a set of the T connectors to tap into the line..
    Well that took me all of 15 min. to hook it up and rout the line through the car..I took it for a test drive and got a video to show it working. I still have to splice it into the dim switch and ground it..
    The hardest part of this install is the location I picked. I'm relocating the fog light switch and mounting the gauge just above the left driver side air vent..I think this is a perfect location for me because I don't want the piller pod. It's a little more sleeper like I guess..I have to take my dremal to the outer/inner dash peceies to get the gauge to fit. I'll be spending some time this weekend with a sanding wheel to get a clean fit/finish. I'll follow with pics this Saturday or Sunday. I'll also upload the video from my phone asap..
    Ohhhh And when you put it to the floor the car boosts 5psi and spikes at 7psi at around 5,000rpms or so and holds until it shifts. Sounds about right for the 3.8" pulley on a stock car?! At idle it sits at about -19#'s or whatever the measurement is for the vacuum side.
    2002 GTP coup 14.6 @ 94mph stock baseline 5-7psi.
    Headers w/o cat, plugs, fwi, 180* t-stat, 3.4, mail-in tune. 13.9 @ 99.75mph 2.2 60'..seeing only 7psi and a fresh set of weatherman snow tires
  2. #2 Re: Boost guage installed..took every bit of 15 min..
    Feb 2009
    Long Grove IL.
    The outer silver part comes off..I just set the gauge here to go for a quick text drive...
  3. #3 Re: Boost guage installed..took every bit of 15 min..
    GT Level Member Joe m's Avatar
    mesa,az
    mine sits anywhere from 10-14 at idle. and sorry i dont like the placement:/ think the pillar pod would look better. but gj!
  4. #4 Re: Boost guage installed..took every bit of 15 min..
    Grand Island, Nebraska
    id suggest putting it in in place of the little cubby hole on the left side. thats where i put the switch for my halos. made that little space useful for once.
  5. #5 Re: Boost guage installed..took every bit of 15 min..
    Feb 2009
    Long Grove IL.
    Thats not where it's going, I just had it sitting there for a test drive...
    I've seen people put the gauge in that lil cubby hole but the steering wheel is in the way of seeing it lol...kinda pointless.
    I'll upload some better pics, it's 2/3's done now..I tapped into the dim switch but I think you guys will like what the finished product looks like!!
    Here's a little better pic...It will literally sit in the spot where the fog light switch was...above the ac/heat vent...almost like a dodge SRT-4 but on the other side of the steering wheel..
  6. #6 Re: Boost guage installed..took every bit of 15 min..
    I get up to -20 VAC depending on what accessories I'm running.
    5-7 PSI sounds right for a well flowing 3.8 setup
  7. #7 Re: Boost guage installed..took every bit of 15 min..
    Feb 2009
    Long Grove IL.
    What do you mean well flowing? It's stock really besides my K&N hot air intake and a res delete..Going to build the fwi this weekend.
  8. #8 Re: Boost guage installed..took every bit of 15 min..
    if your engine wasn't flowing well enough, you'd see more than 5-7 psi of boost.
  9. #9 Re: Boost guage installed..took every bit of 15 min..
    Feb 2009
    Long Grove IL.
    Ahhh gotcha yeah makes sense. What do you think of the spot I picked for the gauge...?
  10. #10 Re: Boost guage installed..took every bit of 15 min..
    MO
    i think you're missing some trim lol
    <brandonl2000> LMAO D!!
  11. #11 Re: Boost guage installed..took every bit of 15 min..
    MA
    i think itll look nice..i wanted to do something like that but said f@ck it..got my a pillar pod in today though! now just waiting on gauges..................
    SMGPFC Member #9
  12. #12 Re: Boost guage installed..took every bit of 15 min..
    Some? he's mising the whole damn thing LOL
    Get a HUD 2 pod guage (and if you don't have a HUD, get one lol)
    or a pillar pod
    I know people go "OH YOU DAMN WANNA BE RACER" but its worth it.
    When i'm done i'll be running an aeroforce, boost/vac, oil pressure and voltage. stock coolant temp guage is so inaccurate is scary...
  13. #13 Re: Boost guage installed..took every bit of 15 min..
    Feb 2009
    Long Grove IL.
    NO WAY!! Weight reduction FTW!!!
    haha naa in the last pic its just setting in their not even hooked up or bolted on. I have the dash piece sitting next to me. I need to do some fine trimming in the car and a bunch of trimming on the piece thats missins in the pics..I'm hoping it turns out like I have it pictured in my head. We shall see. I'll have it done tomorrow.
  14. #14 Re: Boost guage installed..took every bit of 15 min..
    Feb 2009
    Long Grove IL.
    The car has the hud but I think the hud pod looks goofy. Pep boys had a 1, 2, or 3 gauge piller pod that I coulda used but I'd rather have it in the dash for some reason. I just think it will turn out cleaner over-all..a little more factory like
  15. #15 Re: Boost guage installed..took every bit of 15 min..
    i would LOVE to replace all the factory guages... but thats costly.... and i dont care enough
  16. #16 Re: Boost guage installed..took every bit of 15 min..
    Feb 2009
    Long Grove IL.
    So I just did some fine trimming inside the dash so the gauge would sit as far above the vent as I could get it..I think so far it turned out well. These pics it's mounted and hooked up..I don't need to remove it again. Now tomorrow I'll spend some time trimming the outer piece and the frame for it...
    Before..unmounted..
    Now
  17. #17 Re: Boost guage installed..took every bit of 15 min..
    go true
  18. #18 Re: Boost guage installed..took every bit of 15 min..
    in a house
    I dunno. It looks like your gonna hack your dash up. Interested to see how this turns out.
  19. #19 Re: Boost guage installed..took every bit of 15 min..
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    U should put a red bulb in it?
  20. #20 Re: Boost guage installed..took every bit of 15 min..
    West Side Michigan
    I wish I had gauges lol I'm thinking of getting rid of the DIC and putting three gauges there. I like that idea too boosted. Pillar gauges are cool, but I like the sleeper look. Besides I want my passengers to see what I see lol
  1. DIC boost guage half filled WOT
    By Perry125 in forum General Tech Discussion
    Last Post: 11-02-2012, 11:28 PM
  2. aftermarket boost guage?
    By reallyfast1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2010, 05:42 PM
  3. installing a boost guage
    By L KELLS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2010, 09:50 AM
  4. Most Accurate Boost Guage?
    By RNUOVR in forum Off Topic Discussion
    Last Post: 01-07-2008, 03:38 PM
