Thread: Oil Pan leak question
Results 1 to 10 of 10
  1. #1 Oil Pan leak question
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    Its kinda dented, and oil has been leaking out of this little spot for a while now. It's just little dribbles here and there but its still leaving a spot on my driveway. I also don't want to change the pan, because that requires me taking the whole engine out and thats just not happening. Can i just clean around the area and put some black rtv gasket maker silicone stuff on the spot or is that a bad idea?
  2. #2 Re: Oil Pan leak question
    Oct 2011
    Toledo, OH
    Drain your oil, and let it sit for a day to get any seepage away from the crack. Clean it real well with a degreaser, scuff it with some sand paper and use something like JB Weld to seal it. Worked for me on a lowered 90 Camaro RS I bottomed out and dented/cracked the oil pan, on a ridiculously tall speed bump in a parking lot.
    7"
  3. #3 Re: Oil Pan leak question
    You don't have to pull a motor to do an oil pan gasket.
    Ohio
    I recommend it though lol I wish I would have pulled the engine when I did mine.
  5. #5 Re: Oil Pan leak question
    For what reason? I would never pull an engine to do a rear valve cover gasket, why pull it to change an oil pan gasket?
    Ohio
    Well when I think about it... If I would have completely took the sub frame out then and only then it would have been an ok job and not have taken me 16 hours.
  7. #7 Re: Oil Pan leak question
    I think the job only pays an hour or two in the labor guides.
    Support motor from above.
    Lower sub a bit
    Pull off U shaped bracket/mount
    Do pan
    Put mount back in
    Subframe back up.
    I know it's a pain to jockey the motor and subframe seperate from the car, but it's not that bad.
    Pays closer to 4
  9. #9 Re: Oil Pan leak question
    Oct 2011
    New Jersey
    I'd just rather not go through all that. Its not even a huge leak, it's just a bit annoying.
  10. #10 Re: Oil Pan leak question
    Especially when it might be a rear engine cover leak.
  1. antifreeze leak question
    By gentrymartin in forum General Tech Discussion
    Last Post: 03-12-2012, 02:37 PM
  2. Tranny Leak question
    By Kenny75k in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-23-2011, 08:42 AM
  3. exhaust leak question
    By oneil.GTP in forum General Tech Discussion
    Last Post: 03-02-2010, 09:43 PM
  4. Coolant spray/leak. Quick fix just 1 question
    By VejGTP in forum General Tech Discussion
    Last Post: 12-26-2009, 11:10 PM
  5. Fuel Leak Question???
    By BDEGhost in forum General Tech Discussion
    Last Post: 11-11-2009, 11:53 AM
