no eggs smells like gas and my car just hit 140000
im a certified tig and mig welder so i think im going to just do a delete since we dont have emissions. and then go from there then thanks a bunch for your in put!
I just thought of another cheap easy one, replace your PCV valve. It is a way out there chance like 1:1000, but its two bucks
Although I’m pretty sure your cat is the issue. I have seen dozens of people that refuse to believe that cats and O2 sensors don’t last forever.
PS deleteing it will give you a perma CEL![]()
i cant buy the little sensor to trick the o2 sensor off of zzp or dont those work
Honestly, I’m not sure they work for 04+.
The only method I do know works is the PCM code delete.
I’d give it a 50/50 chance
ok figured it out guys after putting it on my fathers scanner and drove it #6 was the only one not firing so did compression test it was good so i got to looking and the wires to the plug for injector were bare an breaking so i repaired that and runs great again thanks for everyones help!
