Thread: ignition wiring help
Results 1 to 9 of 9
  1. #1 ignition wiring help
    Leightion, IA
    Ok,
    So, I know I am doing a crazy mad system (sound system) in my car... I have a Rockford Fosgate regulator that I am installing (thing was basically given to me and I figure why not use it)... I just am not sure how to get it wired up so it turns on only when the car is in the ON position... not ACC.... otherwise I would just connect it to the Remote wire off the head unit... anyone ever messed with the ignition switch wires and know what one may be the best to pig tail off and were is the best, closest way to get to it near the head unit??
    Thanks,
    Timmi
  2. #2 Re: ignition wiring help
    Willoughby, Ohio
    the remote wire is supposed to go to the head unit, there is a wire just for that.
    why would you want to wire it like that?
  3. #3 Re: ignition wiring help
    Leightion, IA
    hold on hold on... your missing what i am doing.. this is not the amp that i am wiring to the ignition.. this is the regulator... its a deal that controls the charge going to my second battery.. I only want it to come on and charge my second battery when the car is on.. not when I am sitting in the driveway cleaning it and have it in ACC... lol.
  4. #4 Re: ignition wiring help
    Willoughby, Ohio
    if u mean by ON as in the engine is running then maybe run it off the alternator?
  5. #5 Re: ignition wiring help
    Leightion, IA
    yea... thats not an option i want to do... lol.. no offense... rather go with pig tailing off the ignition switch... was just looking for someone who would know the wire color that i need to look for and where the best location for finding it would be....
  6. #6 Re: ignition wiring help
    Willoughby, Ohio
    ok ok well now that we are on the same page, im afraid i cant help you haha. im not familiar with the ignition wires. hopefully some1 else will chime in to help u
  7. #7 Re: ignition wiring help
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    i just installed a remote starter with the help of my factory service manual, so ignition wiring info is fresh in my head. your looking for a wire that is only on when the key is on, correct? if so, you will want to tap into the orange wire in the ignition harness. if you also want voltage when your key is turned backwards to the "accessory" position, you will want the brown wire instead. if you dont get the results you want with either option, no matter what, do not splice the 2 wires together.
    what i would do if i were you is just use a constant 12 volt wire with a toggle switch for your application. in the ignition harness, the red and red/white wires are both 12 volt constant
    if you need anything else just let me know
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  8. #8 Re: ignition wiring help
    Leightion, IA
    orange wire... thats what I needed... also... do I have to go into the steering column to find it or is it accessable from under the dash area on the drivers side?? I assume yes... just curious.
  9. #9 Re: ignition wiring help
    Nov 2008
    Fremont Nebraska
    you wont need to remove the steering wheel column, but you will need to remove the stuff underneath it.
    you start with a little carpet piece thats held in with only 2 fasteners. then the next piece is held in by 2 screws (which are right next to those 2 fasteners you just undid) and 3 fasteners that just pull out on the top. after removing these 2 piece you SHOULD have enough access to the ignition wires. if not theres 1 more piece you can remove, it will be the black steel piece you now see. it is held in by 2 screws and 4 bolts... the bolts are absolutely impossible to get to without extensions, jtlyk
  1. I can't take my key out of the ignition!
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 09-06-2010, 11:10 AM
  2. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  3. Ignition not turning
    By alee90 in forum General Tech Discussion
    Last Post: 03-08-2009, 10:07 AM
  4. Wiring Diagram, Ignition/security system
    By boogsey in forum General Tech Discussion
    Last Post: 12-25-2008, 11:32 PM
  5. Need More Help, Ignition
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-28-2008, 12:17 AM
