Thread: A look at different types of spark plugs
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #21 Re: A look at different types of spark plugs
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Yeah man, those suckers so woke up the engine that I proceeded out on a test drive and shredded my differential...
    and Trannyman popped a piston on his first run with a set of Brisk silver racing plugs installed
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #22 Re: A look at different types of spark plugs
    TDCRacing
    Guest
    wow....thats odd...almost makes me not want to get them lol
  3. #23 Re: A look at different types of spark plugs
    St Louis MO
    Quote Originally Posted by TDCRacing View Post
    It's a sign.
    just an oddity... I can certainly buy those plugs killing a transmission, but popping a piston...no way
    2010 Camaro SS LS3
  4. #24 Re: A look at different types of spark plugs
    Saraland Alabama
    Here is a link to some dyno results using the Pulstar plugs in a Dodge Neon. Not the glowing numbers they would have you believe. In fact, I have seen very similar numbers from such plugs as E3's and Sidegapped plugs.
    Sparkplugs.com - Spark Plug 411
    I wonder what would have happened just switching to another set of champion plugs (I didn't see where it said the ones in the car were new)
  5. #25 Re: A look at different types of spark plugs
    Oklahoma
    Good point. The idea behind Pulstar plugs is sound. In other words, plasma ignition is not really anything new. What troubles me with the Pulstar plugs is the voltage claims they make. I just dont see how those numbers are possible. In a modern electrical ignition system, the math doesnt work.
  6. #26 Re: A look at different types of spark plugs
    SE Level Member Fritcr's Avatar
    Apr 2008
    I can tell you all for sure...don't ever buy Bosch Platium Plugs. I put them in my wife Bonniville and it would not run right. I finally took them out and put some AC's in it and it was fine. Then I had a 98 Stratus that would not idle right when I bought it and I checked..sure enough...Bosch Platiums so I switched them out with Autolights and that fixed it.
    Rob
  7. #27 Re: A look at different types of spark plugs
    Oklahoma
    Im pretty convinced that its not so much BOSH as it is the configuration of the plug. Its a surface discharge plug. It should work better with lower voltage ignition systems, but making it a platinum plug changes that slightly. It doesnt take as much voltage for a surface gap plug, but I believe when it does spark its not as strong as a conventional plug.
  8. #28 Re: A look at different types of spark plugs
    Saraland Alabama
    I agree, I run the bosh in my bravada with no problems, but in the gp so far has been autolite (may try some ngk next, but will never run another ac plug or champion have had too many problems from both)
  9. #29 Re: A look at different types of spark plugs
    Apr 2008
    You all have problems with AC's? I haven't but have to say...I don't think I have had a problem with NGK's. I don't even know what's in the GP. I need to look at them. To many other problems right now with it. It runs good so I figure I'll check them when have a little time.
    Rob
  10. #30 Re: A look at different types of spark plugs
    TDCRacing
    Guest
    is everyone refering to ac's meaning ac delco?? just checking
  11. #31 Re: A look at different types of spark plugs
    Saraland Alabama
    I am ( realize they are no longer gm made products either)
  12. #32 Re: A look at different types of spark plugs
    TDCRacing
    Guest
    ok i was just checking
  13. #33 Re: A look at different types of spark plugs
    Apr 2008
    That's what I was talking about.
  1. Side Gap Spark Plugs [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 03-17-2010, 12:26 PM
  2. Pulstar Spark Plugs.....Gimmick or legit?
    By GeddyLee in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2009, 12:38 AM
  3. Plugs???
    By crashman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2008, 10:00 PM
  4. would hi-mileage/worn spark plugs cause KR at WOT/PE?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 08:15 AM
