Thread: supercharge pully replace
Results 1 to 12 of 12
  1. #1 supercharge pully replace
    Feb 2010
    barrie,ont,CANADA
    hey has anyone on here replaced the couplier on there super charger? mine is making noise, and i was told in order to change it i have to pull the whole nose off is this true? and if so is it alot of work?
    thanks in advance.
  2. #2 Re: supercharge pully replace
    Feb 2010
    barrie,ont,CANADA
    oh yes and sorry this is on a 1998 gtp 4 door automatic
  3. #3 Re: supercharge pully replace
    yes, you have to pull the snout off the blower to get at the coupler. its an easy job.
  4. #4 Re: supercharge pully replace
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    easy should only take ya a half hr. if that, get the coupler first and the oil they are hard (sorta) to get most of tyme there outa stock
    1 take belt off
    2 unbolt snout
    3 pull snout off remove old coupler
    4 put new coupler on
    5 line snout up with coupler dont force it should go on with ease if lined up properly
    6 make sure you put sum kind of sealant on snout (can get at gm).
    7 bolt it up
    8 fill it up with the special blower oil (can get at gm)
    9 put belt back on
    10 you are done
  5. #5 Re: supercharge pully replace
    Apr 2009
    stockton ca
    What he forgot to mention is the oil in the blower is some nasty smelling sh1t that you might not want all over your engine
    If it were me i would take the blower off to do it
    but that would mean pulling the injectors and fuel rails
  6. #6 Re: supercharge pully replace
    i always pulled the blower off. it is much easier that way and much less messy.
  7. #7 Re: supercharge pully replace
    Feb 2010
    ohio
    my bad oil does smell discusting ,but nuthin a lil degreaser and water wont take care of, i usally suck it out with a sucsion pump but not all ppl have access to one
  8. #8 Re: supercharge pully replace
    Use a turkey baster...everyone has access to one and it does just as good of a job.
  9. #9 Re: supercharge pully replace
    Largo, Florida, United States
    i replaced the SC oil this weekend i had the entire upper intake off and just turned it upside down on my work bench took like 2 mins to drain out. smelled Horrid.
    takes about 8OZ's to fill FYI
  10. #10 Re: supercharge pully replace
    So...it is an N/A Upper intake on a supercharger...
    hmmm.
  11. #11 Re: supercharge pully replace
    Banned - Busted For Scamming
    Feb 2009
    hmmm.
    Oh come on nick, you know what he meant. I think he did his lim gaskets.
  12. #12 Re: supercharge pully replace
    Because the LIM is so far up in the motor.
  1. Supercharge it?
    By zewski2469 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-29-2009, 05:03 PM
  2. Pully
    By offroadfury6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-26-2008, 11:58 AM
  3. Supercharge a GT (L36)???
    By whitedudedown in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-12-2008, 06:21 PM
  4. Pully
    By 40thgtp in forum General Tech Discussion
    Last Post: 03-24-2008, 07:42 PM
