hey has anyone on here replaced the couplier on there super charger? mine is making noise, and i was told in order to change it i have to pull the whole nose off is this true? and if so is it alot of work?
thanks in advance.
thanks in advance.
oh yes and sorry this is on a 1998 gtp 4 door automatic
easy should only take ya a half hr. if that, get the coupler first and the oil they are hard (sorta) to get most of tyme there outa stock
1 take belt off
2 unbolt snout
3 pull snout off remove old coupler
4 put new coupler on
5 line snout up with coupler dont force it should go on with ease if lined up properly
6 make sure you put sum kind of sealant on snout (can get at gm).
7 bolt it up
8 fill it up with the special blower oil (can get at gm)
9 put belt back on
10 you are done![]()
What he forgot to mention is the oil in the blower is some nasty smelling sh1t that you might not want all over your engine
If it were me i would take the blower off to do it
but that would mean pulling the injectors and fuel rails
Use a turkey baster...everyone has access to one and it does just as good of a job.
i replaced the SC oil this weekend i had the entire upper intake off and just turned it upside down on my work bench took like 2 mins to drain out. smelled Horrid.
takes about 8OZ's to fill FYI
Because the LIM is so far up in the motor.
