Thread: Misfiring
Results 1 to 4 of 4
  1. #1 Re: Misfiring
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    It's a good time to change your spark plugs and maybe wires and do it today because a misfire will dump fuel into your exhaust and fry your catalytic converter making this a more expensive repair. Just stick with platinum ones if you plan to continue running a stock motor. P0303 is cylinder 3 misfire, it's the center cylinder towards the front of the car and at the very least change that plug now.
    If new plugs and wires properly installed don't solve your problem then the misfire is caused by a bad fuel injector, I doubt a bad coil pack because cylinder 6 is not misfiring.
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  1. Misfiring
    By Dropped GP GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2009, 07:15 PM
  2. *HELP*car stutters and feels like misfiring above 50% throttle
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2009, 01:47 AM
  3. need help!! misfiring???
    By icolex1 in forum General Tech Discussion
    Last Post: 02-26-2009, 03:49 PM
  4. Misfiring?
    By hotshot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-05-2008, 09:33 PM
  5. Help!! '01 GTP misfiring/idiling rough at startup!!
    By fatride99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2008, 06:20 PM
