Thread: p0420 code, which o2 sensor do i replace?
Results 1 to 10 of 10
  1. #1 Re: p0420 code, which o2 sensor do i replace?
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    spark plug non fouler go-around fix my problem
    I might live under a rock, but can you explain this for me?
    For all your 3800 needs:
  2. #2 Re: p0420 code, which o2 sensor do i replace?
    SE Level Member GTPcoupe's Avatar
    Feb 2010
    Canada
    Quote Originally Posted by copgtp View Post
    This is useful if you have a hi flow cat that sets off the engine light and dont have a custom tune that deletes the code. It's just a peice you screw on to the end of the 02 sensor and then screw it in the pipe. It pulls the sensor back out farther so it detects less and tricks the sensor.
    '99 GTP coupe - Growing mod list/summer car
    '98 GTP Sedan - Winter ride, 315,000+kms and going strong!
  1. P0420 code
    By BChimo in forum General Tech Discussion
    Last Post: 10-18-2012, 12:18 PM
  2. po341 cam sensor circuit code
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-19-2009, 12:07 AM
  3. If i delete the rear 02sensor code(p0420)
    By kinglou10 in forum PCM Tuning
    Last Post: 07-02-2009, 05:22 PM
  4. P0420 Code keeps setting on 2001 GTP
    By Littlegiant in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 07:50 PM
  5. p0420 code on
    By fst in forum General Tech Discussion
    Last Post: 01-05-2008, 04:19 PM
