Thread: Think im leaking coolant
Results 1 to 8 of 8
  1. #1 Think im leaking coolant
    Feb 2010
    Connecticut
    Ok so my low coolant light light went on a few weeks ago so my first instinct was to go buy some coolant and dump it in. The "low coolant" light went off for about a week and then came on again. I grabbed another container of coolant and used it cautiously this time seeing as the light only came on when my car was first started then turned off once the engine was warm. After checking the engine bay for a leak I noticed a very small puddle of what I think may be coolant directly below the intake manifold where it says hidden bolt here or something or other right where the upper radiator hose connects to the engine..any suggestions as to what the problem may be? Thankss in advance
  2. #2 Re: Think im leaking coolant
    henderson co
    These have a couple of issues normally,i have recently had to replace my sensor.light came on and rad was full.no problems after i replaced it.Also gm has updated these intake gaskets a few times,if they are the plastic original gaskets they need to be replaced to the new thicker aluminum ones,they work much better.i would bet that would take care of your problems
  3. #3 Re: Think im leaking coolant
    Apr 2009
    stockton ca
    The coolant light is bs Mine comes on and i have flushed the system and bled it still comes on every morning hell may need to bleed it again
  4. #4 Re: Think im leaking coolant
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Check the coolant elbows.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  5. #5 Re: Think im leaking coolant
    GT Level Member JessinaterGTP's Avatar
    Elmira ny
    Quote Originally Posted by JoshMcMadMac View Post
    i just did mine
  6. #6 Re: Think im leaking coolant
    Feb 2010
    Connecticut
    I don't have pictures right now but ill try and get some up soon. I've read that these cars are notorious for lower intake manifold gasket leaks and I was really hoping that thy wasn't the case lol. How much does the new sensor light cost roughly? Starting to think I should take it to the shop
  7. #7 Re: Think im leaking coolant
    SE Level Member PolishedandWaxed's Avatar
    Delta, OH
    mines on until it warms up. got pics of the coolant elbows?
  8. #8 Re: Think im leaking coolant
    henderson co
    The sensor thru the dealer is around $60 bucks.the lower intake is not hard to reseal.if you want to bring it out to denver i can help you with it. lol.
  1. leaking coolant
    By pacothetaco in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-04-2010, 11:25 AM
  2. Leaking coolant.
    By c002529 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-16-2010, 12:21 PM
  3. Leaking Coolant
    By seeth001 in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-23-2009, 06:03 PM
  4. S/C Leaking???
    By jagamite in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 08:53 PM
  5. leaking coolant
    By rdicarlo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 10:04 AM
